[Solved] Help to add ComboBox item
cean
New Contributor II
I am following this to try to write a SDI code: Designing a Dialog Box Overview (intel.com)
I have put a Combo Box on my Form, how do I add item in it? Is there a simple code sample?
Cheers,
Cean
andrew_4619
The drop down size is not on the property sheet. In the dialog editor you define the size of a control in the GUI. If you click the combo box drop down button in the GUI to expand it you can drag the grips to change the size.
cean
New Contributor II
Sorry, found it. Don't know how to delete my post.
Using List Boxes and Combo Boxes (intel.com)
cean
New Contributor II
Got an empty list same as this:
combo box - Intel Community
Steve_Lionel
You're not giving us much to work with. How about ZIPping your project (after doing a Build > Clean) and attaching the ZIP to a reply here?
cean
New Contributor II
Hi Steve,
I use the template to create a SDI program and add one menu item (tDialog) under the File menu. It opens a Dialog. The Dialog has two Combo boxes. I could add the items now, but when click the Arrow, it doesn't show the list correctly, only a narrow area. Hard to scroll up & down.
Cheers,
Cean
andrew_4619
In the dialog editor you need to define the size of the area when the combo drops down.
cean
New Contributor II
Which properties?
Sometimes I got the right display without any change. But other times, it only show that narrow strip.
Steve_Lionel
You need a lot more for a combo box. You can start reading here: Using List Boxes and Combo Boxes (intel.com)
cean
New Contributor II
Is there a full code from this tutorial?
andrew_4619
cean
New Contributor II
Steve_Lionel
Is a combo box really what you want? This combines a list box with a user-entry field.  @andrew_4619 has the right idea on changing the size of the visible box.
cean
New Contributor II
It's better the software's default could display correctly at the first place. That is showing a scroll bar with 2 lines with one up arrow and one down arrow. Or a default area bigger than 2 lines. If total items less than default area, no scroll bar is needed.
Then, If the user need to change,  he could  go back to design.
andrew_4619
The resource editor is a Microsoft Product and is not part of Intel Fortran.
cean
New Contributor II
