I'm working on a large main program (3000+ lines) and get a compiler note that "space is exceeded for data dependence test" and (evidently) it isn't doing the optimization it could. Is this a hard-coded space limit, or is there a setting/environment variable that can be set to provide more room? As it turns out, it would certainly be difficult to follow the suggestion in the note which is to subdivide the code into multiple routines.
David DiLaura
WindowXP service pack 2, Fortran 10.1.011, Studio 2005
Would you please report this to Intel Premier Support and attach a test case? 3000 lines is not what I would call large. 30,000 lines, maybe...
