29642 Discussions
mixed programming problems with strings
pdehon
I try to call a C++-function by a Fortran program. In C++ I only receive the first character whatever combinations of VALUE or REFERENCE attributes are applied. What can be the reason?
Fortran looks like this :
interface
integer function fn(A)
!DEC$ ATTRIBUTES DLLIMPORT, DECORATE, ALIAS:'fntestlib2' :: fn
CHARACTER(5) A
end function
end interface
! Variables
integer res
res = fn('test')
C++ :
extern
"C"
__declspec
(dllexport)
int fntestlib2(char* s, unsigned int len_arg);
__declspec
(dllexport)
return 42;
Lorri_M_Intel
I wasn't able to reproduce the failure you described using this program. Actually, I made two changes. In the Fortran program, I null-terminated the string, as:
res = fn('test'//char(0))
And, in the C++ program I output the string that was passed in, and it looked fine.
I assume there is a DLL involved here, based on the "dllimport/dllexport" directives; is there a chance your test is finding the wrong DLL?
- Lorri
