29421 Discussions
Static vars and runtime loading of dll library
Roberto_Sartori
I have this problem, I've got a DLL which is loaded and unloaded at runtime many times. I need to mantain some data values between one loading time and the following loading time. how can I do that?
Jugoslav_Dujic
Valued Contributor II
Quoting - Roberto Sartori
Well, don't load it and unload so many times then :-D.
Generally, you can't persist the variables in memory between subsequent loads, (obviously, because you cannot know when the caller is going to reload your dll).
What you can do is to persist the data to a (semi-)permanent storage (disk file, registry, or a shared memory file if you desperately need speed). The best place for that would be cases DLL_PROCESS_ATTACH and DLL_PROCESS_DETACH of your DllMain function. Note that, generally, this processing in DllMain should be fast and simple (see http://blogs.msdn.com/larryosterman/archive/2004/04/23/118979.aspx).
