I downloaded w_fc_pc_8.1.028 when I was made aware of its release via the usual IPS Notification. Given that there have been several threads on the forum concerning w_fc_pc_8.1.028 is it now save to install it?
Gerry T.
Gerry T.
It hasn't changed. I would avoid installing this if you use QuickWin. For most others, it should be ok. You can always go back to 8.1.025 if needed.
Topic Options
