- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi all,
About 6 months ago I downloaded an example from this site that showed how torun a fortran dll fromC# (visual studio). Helped me greatly.
When I ran it I was able to set a breakpoint in the IVF code and then step through the code. It was so cool.
At the time I looked all around at the differences between that app and mine and could never find the answer. Now I can't find the example. :-(
Does anyone know how to setup Visual Studio so you can step in to the IVF code?
I appreciate the help.
Eric
- Balises:
- Intel® Fortran Compiler
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Steve,
Thanks for the response.
I don't have an "enable debugging of unmanaged code" check box. I click on the C# project, then right click and select debug, I get two selections 1)Start new instance and 2) Step into new instance.
Am I missing a patch for Visual Studio?
Thanks again,
Eric
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
My bad... thanks.
When I change that parameter and ran the application I get the error "Error while trying to run project. Unable to start debugging."... "The server threw an exception".
Have you seen that error before? Or do I have something out of wack in the code?
thanks,
Eric
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
1. Uninstalling the Intel Fortran VS integration
2. Doing a "reinstall/repair" of Visual Studio (from add/.remove programs, change/modify)
3. Reinstall Intel Fortran VS integration
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Ugh... is not the word I used. I am now unable to build my project
I did items 1 and 2. But when I went to install the integration I got the following error.
You have a previously integrated Compiler with Visual Studio. The previous version must be uninstalled prior to install this one.
So I uninstalled all installed partsof fortran and reinstalled them, same error.
So I uninstalled all installed partsof fortran and reinstalled Repaired VS and then installed all fortran. Everything installed except VS integretedThe button is marked as "Install" (instead of Modify)
Appreciate any thoughts on where I can go from here.
Eric
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Will do... Thanks for your help.
Eric
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Update... The problem I had appears to be with IVF 8.1 that was also installed. I am not sure why or how IVF 8.1 was installed but maybe I upgraded to 9.
I uninstalled everything for IVF9 and the Fortran Compiler Integration would not install again. Once I unistalled IVF 8.1 then the install worked.
Eric
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
