29418 Discussions
Strange behavior in constructor of derived type with allocatable string
hs-napa
Running the following simple program gives strange output.
[bash] MODULE TEST_MOD
   IMPLICIT NONE
   TYPE STRING
      CHARACTER(LEN=:), ALLOCATABLE :: S
   END TYPE
END MODULE
PROGRAM TEST
   USE TEST_MOD
   IMPLICIT NONE
   TYPE(STRING) :: A, B, C
   A = STRING('ABC')
   B = STRING('ABCDEFG')
   C = STRING('ABCDEFGHIJ')
   WRITE(*,*) A % S, LEN(A % S)
   WRITE(*,*) B % S, LEN(B % S)
   WRITE(*,*) C % S, LEN(C % S)
END PROGRAM
[/bash]
Compiling and running the program gives the following output:
>ifort constructor.f90
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20091130 Package ID: w_cprof_p_11.1.054
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:constructor.exe
-subsystem:console
constructor.obj
>constructor.exe
ABC 3
ABC 3
ABC 3
All the allocatable strings are the same length. When changing the order of constructors as follows:
[bash]   A = STRING('ABCDEFGHIJ')
   C = STRING('ABC')
[/bash]
and recompiling and running the test program gives the following output:
>constructor.exe
ABCDEFGHIJ 10
ABCDEFG 10
ABC 10
What the ...? I naively assumed to get strings with different lengths.
Again, if the initialization of A, B and C is changed to:
[bash]   A % S = 'ABC'
   B % S = 'ABCDEFG'
   C % S = 'ABCDEFGHIJ'
[/bash]
The output is what I expected to get in the first case:
>constructor.exe
ABC 3
ABCDEFG 7
ABCDEFGHIJ 10
Is this a feature or a bug?
BR,
-Heikki
mecej4
This error does not occur with the more recent releases 11.1.065 or 11.1.067.
