ifort bug on deallocate
Alfredo_Buttari
I found a bug in the ifort compiler. The deallocate statements in the code below return with a 173 error:
[fortran]program test_bug
  implicit none
  integer, pointer :: irn(:), jcn(:)
  integer, pointer :: tmp(:)
  integer :: error
  allocate(irn(10))
  allocate(jcn(10))
  tmp => irn(:)
  irn => jcn(:)
  jcn => tmp(:)
  nullify(tmp)
  deallocate(irn, stat=error)
  write(*,*)error
  deallocate(jcn, stat=error)
  write(*,*)error
  stop
end program test_bug
[/fortran]
I found the same issue in ifort V11.0 and V11.1 on the intel64 architecture. Didn't have any chance to test it on ia32. Is this bug known and/or already fixed?
best regards
alfredo
PS
I'm not sure whether this is correct way of reporting bugs but I couldn't find any other way. Is there any "official" mean to report bugs?
TimP
deallocate(irn, stat=error,errmsg=error_message)
write(*,*)error,trim(error_message)
$ ./ab
173
A pointer passed to DEALLOCATE points to an array that cannot be deallocated
173
I guess your point is you would like an option for compile-time error diagnostics? I suppose the section of an allocatable array (even if it copies the entire array) is distinct from the original allocated array and is not deallocatable. I didn't quickly find an expert discussion of your usage.
Evidently, with change to textbook syntax:
tmp => irn
irn => jcn
jcn => tmp
the behavior also changes to textbook style.
If you didn't set up a support account when you installed ifort, you can register your serial number at https://registrationcenter.intel.com and use the account at premier.intel.com to file your bug or feature request.
Alfredo_Buttari
Tim,
I now realize that my code tries to deallocate a section of an array (even if the section corresponds to the whole array). I got fooled by the fact that the same code works with gfortran. I slightly modified the title of the thread and removed the word "bug".
Best regards
alfredo
mecej4
Here are the sections of the standard that rule out using an array section as target instead of an array in this context:
Section 7.4.2:
8 R735 pointer-assignment-stmt is data-pointer-object [ (bounds-spec-list) ] => data-target
28 R739 data-target is variable
29 or expr
30 C723 (R739) A variable shall have either the TARGET or POINTER attribute, and shall not be an
31 array section with a vector subscript.
Alfredo_Buttari
Mecej,
thanks your your very useful explanation.
alfredo
