I'm sorry about the short description but with the example, I think it's better.
I have a strange behaviour with Intel Fortran compiler since ifort 11.xxx.xxx.
Here my code:
The length of the argument HMFILE is 1 and not 28 as expected.
When I compile with gfortran-4.4.4, I got the expected behaviour:
Can you tell where I'm wrong?
Thank you in advance.
Laurent,
Here my code:
[fortran]MODULE MODI_TURB
contains
SUBROUTINE TURB( &
HLBCX, &
HLBCY, &
HTURBDIM, &
HTURBLEN, &
HTOM, &
HTURBLEN_CL, &
HINST_SFU, &
HUVW_ADV_SCHEME, &
HFMFILE, &
HLUOUT, &
PDXX, &
PDYY, &
PDZZ, &
PDZX, &
PDZY, &
PZZ, &
PCOSSLOPE, &
PSINSLOPE, &
PRHODJ, &
PTHVREF, &
PRTKES &
IMPLICIT NONE
CHARACTER(LEN=4),DIMENSION(2),INTENT(IN) :: HLBCX
CHARACTER(LEN=4),DIMENSION(2),INTENT(IN) :: HLBCY
CHARACTER*4 ,INTENT(IN) :: HTURBDIM
CHARACTER*4 ,INTENT(IN) :: HTURBLEN
CHARACTER*4 ,INTENT(IN) :: HTOM
CHARACTER*4 ,INTENT(IN) :: HTURBLEN_CL
CHARACTER*1 ,INTENT(IN) :: HINST_SFU
CHARACTER(LEN=6) ,INTENT(IN) :: HUVW_ADV_SCHEME
CHARACTER(LEN=*) ,INTENT(IN) :: HFMFILE
CHARACTER(LEN=*) ,INTENT(IN) :: HLUOUT
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PDXX
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PDYY
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PDZZ
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PDZX
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PDZY
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PZZ
REAL, DIMENSION(:,:) ,INTENT(IN) :: PCOSSLOPE
REAL, DIMENSION(:,:) ,INTENT(IN) :: PSINSLOPE
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PRHODJ
REAL, DIMENSION(:,:,:) ,INTENT(IN) :: PTHVREF
REAL, DIMENSION(:,:,:) ,INTENT(INOUT) :: PRTKES
print*,"IN SUBROUTINE TURB :: LEN(HMFILE)=",LEN(HFMFILE)
print*,"IN SUBROUTINE TURB :: LHMFILE=",HFMFILE
END SUBROUTINE TURB
end MODULE MODI_TURB
program main
use MODI_TURB
implicit none
CHARACTER(LEN=4),DIMENSION(:),POINTER :: HLBCX
CHARACTER(LEN=4),DIMENSION(:),POINTER :: HLBCY
CHARACTER*4 :: HTURBDIM
CHARACTER*4 :: HTURBLEN
CHARACTER*4 :: HTOM
CHARACTER*4 :: HTURBLEN_CL
CHARACTER*1 :: HINST_SFU
CHARACTER(LEN=6) :: HUVW_ADV_SCHEME
CHARACTER(LEN=16),POINTER :: HLUOUT
REAL, DIMENSION(:,:,:), POINTER :: PDXX,PDYY,PDZZ,PDZX,PDZY
REAL, DIMENSION(:,:,:), POINTER :: PZZ
REAL, DIMENSION(:,:), POINTER :: PDIRCOSXW, PDIRCOSYW, PDIRCOSZW
REAL, DIMENSION(:,:), POINTER :: PCOSSLOPE
REAL, DIMENSION(:,:), POINTER :: PSINSLOPE
REAL, DIMENSION(:,:,:), POINTER :: PRHODJ
REAL, DIMENSION(:,:,:), POINTER :: PTHVREF
REAL, DIMENSION(:,:,:), POINTER :: PRTKES
CHARACTER(LEN=28),POINTER :: HFMFILE
ALLOCATE(HFMFILE) ; HFMFILE = "abcdef_file "
ALLOCATE (HLBCX(2)) ; HLBCX(:) = "CYCL"
ALLOCATE (HLBCY(2)) ; HLBCY(:) = "CYCL"
print*,"IN MAIN :: LEN(HMFILE)=",LEN(HFMFILE)
print*,"IN MAIN :: LHMFILE=",HFMFILE
call TURB( &
HLBCX, &
HLBCY, &
HTURBDIM, &
HTURBLEN, &
HTOM, &
HTURBLEN_CL, &
HINST_SFU, &
HUVW_ADV_SCHEME, &
HFMFILE, &
HLUOUT, &
PDXX, &
PDYY, &
PDZZ, &
PDZX, &
PDZY, &
PZZ, &
PCOSSLOPE, &
PSINSLOPE, &
PRHODJ, &
PTHVREF, &
PRTKES &
DEALLOCATE(HFMFILE)
DEALLOCATE(HLBCX)
DEALLOCATE(HLBCY)
end program main
[/fortran] And its output:[bash]$ ifort -V;ifort -g prog.f90;./a.out Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.4.191 Build 20110427 Copyright (C) 1985-2011 Intel Corporation. All rights reserved. IN MAIN :: LEN(HMFILE)= 28 IN MAIN :: LHMFILE=abcdef_file IN SUBROUTINE TURB :: LEN(HMFILE)= 1 IN SUBROUTINE TURB :: LHMFILE=a [/bash]
[bash]$ gfortran prog.f90;./a.out IN MAIN :: LEN(HMFILE)= 28 IN MAIN :: LHMFILE=abcdef_file IN SUBROUTINE TURB :: LEN(HMFILE)= 28 IN SUBROUTINE TURB :: LHMFILE=abcdef_file [/bash]If I modify the source by delete argument from the subroutine TURB, I've got the correct behaviour. With Intel Fortran Compiler <11.xxx, it worked.
Laurent,
Please refer to the following KB article:
This is a recently discovered bug in the compiler, but it has a workaround.
The fix is to add the following switch when compiling this code:
-switch fe_inline_all_arg_copy_inout
Hi Michael!
I thank you for the answer. I didn't find it because it was hard to describe for me.
Laurent,
Laurent,
