Suspected optimizer bug
mecej4
The program below gives correct results when compiled with /Od, and incorrect results with /Ot or /O2. I suspect that this is an optimizer bug since, if one of the following slight changes is made, the bug goes away: (i) uncommenting the WRITE statement on line-29, (ii) commenting out the WRITE statement on line-37 or (iii) making the array A a statically allocated array.
The problem bears some resemblance to another optimizer bug with older versions of the Linux Ifort compilers that I reported on about a month ago ( http://software.intel.com/en-us/forums/showthread.php?t=73629 ); however, I thought that since I have now seen this bug with the Windows compiler, it might be appropriate to report it.
The results with /Od:
E:\\IBUG>ifort /Od tsc.f90 & tsc
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 2010041
4 Package ID: w_cprof_p_11.1.065
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Microsoft Incremental Linker Version 9.00.30729.01
Copyright (C) Microsoft Corporation. All rights reserved.
-out:tsc.exe
-subsystem:console
tsc.obj
A2 = 1 2
A3 = 2 3
A4 = 1 2 3
Am = 1 2 3
and, with /O2:
E:\\IBUG>ifort /O2 tsc.f90 & tsc
-out:tsc.exe
-subsystem:console
tsc.obj
A2 = 2 2
A3 = 2 2
A4 = 1 2 2
Am = 1 2 2
The program source:
[fortran]program TSChur
implicit none
INTEGER, ALLOCATABLE, DIMENSION( : ) :: A
allocate(A(3))
call Scomp( A )
write(*,10)' Am = ',A
stop
10 format(1x,A10,3i4)
contains
SUBROUTINE Scomp( A )
implicit none
INTEGER, DIMENSION( 2 ) :: Kcol = (/1,2/)
INTEGER :: i, i1, i2, ii, ij, ipos, j, j1, j2, jj
INTEGER :: ls
IF (.NOT.ALLOCATED(A))ALLOCATE(A(3))
A( : 2 ) = 0
DO ii = 1, 2
A( Kcol( ii ) ) = A( Kcol( ii ) ) + 1
END DO
! write(*,10)' A1 = ',A(1:2)
j = 1
DO i = 1, 2
ii = j
j = j + A( i )
A( i ) = ii
END DO
write(*,10)' A2 = ',A(1:2)
DO i = 1, 2
j = Kcol( i )
jj = A( j )
A( j ) = A( j ) + 1
END DO
write(*,10)' A3 = ',A(1:2)
DO i = 2, 1, - 1
A( i + 1 ) = A( i )
END DO
A( 1 ) = 1
write(*,10)' A4 = ',A
return
END SUBROUTINE Scomp
end program tschur
[/fortran]
Thanks - I can reproduce this. We'll check it out.
mecej4
Thanks for looking into this bug. The bug is also present in the following older version for IA64 (sorry, I don't have access to an IA64 system with the current Intel Fortran Compiler installed):
[mecej4@login2 LANG]$ ifort -V
Intel Fortran IA-64 Compiler for applications running on IA-64, Version 10.1 Build 20080801 Package ID: l_fc_p_10.1.018
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
[mecej4@login2 LANG]$ ifort -O2 tsc.f90
[mecej4@login2 LANG]$ ./a.out
A2 = 0 2
A3 = 1 3
A4 = 1 1 3
Am = 1 1 3
[mecej4@login2 LANG]$ ifort -O0 tsc.f90
A2 = 1 2
A3 = 2 3
A4 = 1 2 3
Am = 1 2 3
It looks as if this bug was recently fixed. I can reproduce it in Update 6, but not in what is eventually going to be Update 7.
mecej4
That's good news, thanks!
