Syntax error due to '&' "when expecting one of: <IDENTIFIER>
Erik_T_
I have written a small parent/child program structure that makes use of ZeroMQ and OpenMP. Until recently I have used gfortran to compile the program but I am now moving to iFort. The code can be found here. However, when compiling using the following makefile (not currently in the repository):
FC=ifort -O2 -openmp
LIBS=libf77zmq.a -lzmq
EXE=hwserver hwclient
.PHONY: default
default: $(EXE)
%: %.f f77_zmq.h libf77zmq.a
	$(FC) $*.f -o $@ $(LIBS) -ffree-form
clean:
	$(RM) -f -- $(EXE) *.ipc
I get plenty of errors regarding ampersands. gfortran complained some about them as well, but they only resulted in warnings. A snippet of the output looks as follows:
ifort -02 -openmp hwserver.f -o hwserver libf77zmq.a -lzmq
fortcom: Error: solve.i, line 324: Syntax error, found '&' when expecting one of: <IDENTIFIER>
        PARAMETER ( INTS_WORDS = 1, &
fortcom: Error: solve.i, line 325: Syntax error, found '&' when expecting one of: <IDENTIFIER>
        &           REALS_WORDS = 2, &
and so it goes on...
I have understood that this is likely caused by ZeroMQ making use of Fortran77 standards, but as aforementioned this turned out to not be a problem when I used gfortran. Fully aware that it might come down to me having to rewrite the ZMQ-bindings, I would like to hear from you first to see if there's another way.
Lorri_M_Intel
Add -free to your ifort command line.
That's our equivalent to the gfortran -ffree-form.
                     --Lorri
Lorri_M_Intel
                     --Lorri
Erik_T_
                     --Lorri
Thank you Lorri, this solved the ampersand problem! The compilation now exits with only warnings.
