29281 Discussions
System call and paths with blanks
aurora
I have this problem when using system call:
The program i want to launch with system command, has blank spaces like
C:Program filesProgram Nameexcutable.exe
So i will have to use "". The thing is that if I try like this:
iflag=system(' "C:Program filesProgram Nameexcutable.exe" --in=C:inputfile ')
the case above works,
but when the inputfile is in a path with "spaces" and i try this:
iflag=system(' "C:Program filesProgram Nameexcutable.exe" --in="C:Documents and settingsinputfile" ')
If fails :(
It seems it doesn't like to have multiple (") in the same system call...but, how can i solve the issue with blank paths then?
Thank you in advance.
PS I have written the statements in a single line although in the real program it is splitted in several lines to avoid problems with the 72 maximum length
anthonyrichards
New Contributor III
In this case ShellExecute is your friend...
USE DFWINTY
TYPE (T_SHELLEXECUTEINFO) SHINFO
CHARACTER*100 EXCEL
INTEGER HWND
INTEGER IRET, retlog
! add your own path to your executable here, or use an environment variable
! that you define, and obtain it using GETENVQQ...
! EXCEL example
EXCEL="C:PROGRAM FILESMICROSOFT OFFICEOFFICEEXCEL.EXE"C
HWND=GETMODULEHANDLE(NULL)
SHINFO%cbSize=sizeof(SHINFO)
SHINFO%Fmask=SEE_MASK_NOCLOSEPROCESS
SHINFO%hwnd=HWND
SHINFO%lpVerb=loc('open'c)
SHINFO%lpFile=loc(EXCEL)
! ADD YOUR FILENAME HERE
SHINFO%lpParameters=loc("C:TEMPDUMMY.XLS"c )
SHINFO%lpDirectory=loc('C:'C)
SHINFO%nShow=SW_HIDE
retlog=ShellExecuteEx(SHINFO)
! CHECK FOR FAILURE...
if(SHINFO%hInstapp.lt.32) then
IRET=MESSAGEBOX(HWND,'Failed to find file//launch EXCEL'C, &
'Problem opening EXCEL'C, &
MB_ICONEXCLAMATION .OR. MB_OK)
endif
Robinson__Donald
This issue still exists in 11.0.061 for both SYSTEM and SYSTEMQQ calls. In my case I want to pass 3 path-names, any of which may contain blanks. The pathnames are quoted to no avail. I suppose I will have to create a batch file, which seems like a lame solution that carries its own file management overhead. It seems to me like this is a deficiency that should be fixed.
IanH
Have a read of the system help (as in Start button > Help and support) for cmd.exe and look at the remarks section. It has some guidelines for quoting. If I follow those things seem to work. In short - try one "super" pair of quotes around the entire line (with each file that contains spaces still in quotes):
[fortran]rc = systemqq('""comand with spaces" "arg with spaces one" "arg with spaces two""')[/fortran]
GVautier
New Contributor III
Hello
but I think that you must write
iflag=system(' "C:Program filesProgram Nameexcutable.exe" "--in=C:Documents and settingsinputfile" ')
because quotes are removed in arguments by the system launcher so the first argument of your executable will be correct.
Robinson__Donald
Thanks Ian - I hadn't seen that bit of help. I'll try this.
