29487 Discussions
Trace/BPT trap: 5 on mac os when moving function to inner function and compiling with -check all
Rivoldini__Attilio
In the code given below the compiled program stops with a Trace/BPT trap: 5 when calling function calculate for a second time and compiling with  -check all with ifort version 19.0.5.281 on mac os 10.14.6 . The function calculate from module mod1 is identical to calculate2 from module mod3 except that the function f1 is an inner function of function calculate and a module function in module mod3. Without the -check all compiler flag there is no Trace/BPT trap: 5 and the code works fine with gfortran 8.1.
Cheers,
AR
module mod
type:: myType
real(8)::val
real(8),allocatable::bigTable(:)
logical,private::flag=.false.
procedure(realFunction1),private,pointer,nopass::f =>null()
contains
    procedure::calc
end type myType
interface myType
module procedure init_myType
end interface myType
abstract interface
function realFunction1(x)
real(8)::realFunction1
real(8),intent(in)::x
end function realFunction1
end interface
contains
type(myType) function init_myType(val,f) result(this)
real(8),intent(in)::val
procedure(realFunction1),optional::f
integer::i
this%val=val
allocate(this%bigTable(1000))
do i=1,1000
    this%bigTable(i)=i
enddo
if (present(f)) then
    this%f=>f
    this%flag=.true.
end if
end function init_myType
real(8) function calc(this,x)
class(myType)::this
if (this%flag) then
    calc=this%f(x)
else
    calc=x
endif
calc=calc+sum(this%bigTable)
end function calc
end module mod
module mod2
use mod
contains
real(8) function calculate(x)
logical,save:: flag=.false.
type(myType),save::m1,m2
if (.not. flag) then
    flag=.true.
    m1=myType(10.d0,f1)
    m2=myType(20.d0)
endif
calculate=m1%calc(x)+m2%calc(x)
contains
real(8) function f1(x)
real(8), intent(in)::x
f1=x
end function f1
end function calculate
end module mod2
module mod3
use mod
contains
real(8) function calculate2(x)
logical,save::flag=.false.
    flag=.true.
    m1=myType(10.d0,f1)
    m2=myType(20.d0)
endif
calculate2=m1%calc(x)+m2%calc(x)
end function calculate2
f1=x
end function f1
end module mod3
program break
use mod2
use mod3,only:calculate2
write(*,*) 'calculate2'
write(*,*) calculate2(1.d0)
write(*,*) calculate2(2.d0)
write(*,*) calculate2(3.d0)
write(*,*) 'calculate'
write(*,*) calculate(1.d0)
write(*,*) calculate(2.d0)
write(*,*) calculate(3.d0)
end program break
