boundary check no warning
Julian_H_
I discovered that the runtime boundary check is not causing any warning in following program. Is this intended?
Intel(R) Visual Fortran Compiler 19.0.5.281 [IA-32]
/nologo /debug:full /Od /warn:all /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc160.pdb" /traceback /check:all /libs:dll /threads /dbglibs /c
MODULE no_warning_mod
    IMPLICIT NONE
    PRIVATE
    PUBLIC :: no_warning, no_warning1
    INTERFACE no_warning
        MODULE PROCEDURE no_warning1
        MODULE PROCEDURE no_warning2
    END INTERFACE
CONTAINS
    SUBROUTINE no_warning1(z)
        IMPLICIT NONE
        INTEGER, INTENT(IN) :: z(:)
    END SUBROUTINE no_warning1
    SUBROUTINE no_warning2(z)
        IMPLICIT NONE
        INTEGER, INTENT(INOUT) :: z(:, :)
    END SUBROUTINE no_warning2
END MODULE no_warning_mod
PROGRAM MWE_boundary_check
    USE no_warning_mod
    IMPLICIT NONE
    INTEGER :: x(10, 02), i
    x(:, 1) = [(i, i = 1, 10)]
    x(:, 2) = [(i, i = 101, 110)]
    ! works as intended
    CALL no_warning(x(:, 2))
    ! no warning
    CALL no_warning(x(:, 3))
    ! no warning
    CALL no_warning1(x(:, 3))
    ! warns
    !x(:, 1) = x(:, 3)
END PROGRAM MWE_boundary_check
jimdempseyatthecove
The bounds checking occurs on the access out of bounds. Try modifying your two subroutines to access the supplied arrays (with bounds issues).
Jim Dempsey
