29433 Discussions
Trace function gives no line numbers or source information
Sander_V_
Hello everyone,
When I compile a program with the -Qvec-report0 -check:all -debug:full -traceback options I get the following Trace window when a error occurs in the code. However the trace windows doensn't provide any line or source information.
I have tested the code with two Intel Fortran Compilers (version 2013 and 2015) and both compilers give the same result. I use Windows 7-64 bit as operating system.
Kind regards,
Sander Vos
Do you have incremental linking enabled? That will disable location information in tracebacks.
