Fix the subscript errors as best as you can until you recover the traceback capability. You may use the debugger or insert PRINT statements in your code to help locate the problem.
I confirmed -traceback is not working again with the Intel Fortran Composer XE 2011 and Xcode 4.1. With -traceback, the stack trace terminates abnormally and without -traceback the traceback is provided but it is not symbolized with source file and line number information.
I was unable to find a convenient work around. I will report this to Development and update the thread when I know more.
(Internal tracking ids: DPD200173457, DPD200175075)
(Resolution Update on 10/17/2014): This defect is fixed in the Intel® Fortran Composer XE 2013 SP1 Update 2 release (Version 14.0.2.139 Build 20140121 - OS X)
Our Developers identified that Lion (10.7.1) introduced address-space layout randomization (ASLR) as a security feature and that this affects the "_trace" section of our traceback code where pointers are not updated accordingly and this leads to the segV.
The earlier suggestion to use "-Wl,-no_pie" should be considered a work around.
I'll update again when I learn more.
Any updates on this issue? OS 10.7.5 + Xcode 4.3.2 + ifort 12.1.4 still seems to have this same problem.
I apologize. I never saw your post from over a year ago. I just recently retested the original test case associated with the internal tracking ids mentioned in my earlier post and confirmed the traceback issues were fixed earlier this year in the Composer XE 2013 SP1 Update 2 (Version 14.0.2.139 Build 20140121 - OS X*) release.
![](/skins/images/06022F5BB6D2F28C8F102671A0F06E85/responsive_peak/images/icon_anonymous_message.png)
