Transfering string sequence to integer array
Vasili_M_
I want to be able to transter a sequence of numbers in a string to an array.
My question is what will be the most intuitive way to behave when the number
of elements in s are different from size of isq
Integer, Allocatable :: isq(:)
Call split ( "2/3/5", "/", isq )
subroutine split (s,delim,isq)
  Character (len=*) :: s
  Character (len=1) :: delim
  Integer :: isq
end subroutine
Vasili_M_
If size(isq) < nfields(s,delim) I fill array elements until size(isq) is reached, neglecting the rest.
When they are same size there is no problem.
So what remains is when size(isq) has more elements being passed.
Vasili_M_
The best thing I found has been not to touch them, unless the user demands to repeat the last element of s.
FortranFan
You may want to consider starting from the basics - see Dr Fortran blog at https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world.  The books mentioned in this blog can give you a sound footing in the fundamentals.
Back to your example, you can allocate the integer array within your procedure which can then make your question moot.
  Character (len=*), intent(in) :: s
  Character (len=1), intent(in) :: delim
  Integer, allocatable, intent(out) :: isq(:)
  allocate(isq(..), stat=..)
end subroutine
Consider the intent specifications for the dummy argument of procedure split: look up the details of intent(out) specification for dummy arguments with allocatable attribute.
jimdempseyatthecove
FortranFan,
I think you intended to count the number of delim's then allocate isq(nDelims+1), then fill in the array.
Jim Dempsey
FortranFan
jimdempseyatthecove wrote:
FortranFan,
Jim Dempsey
Yes, you're right Jim.
