Trouble with multiline OpenMP directives
Ioannis_K_
I am trying to compile a fixed-form Fortran program, and I need to call a very long openMP directive. I tried to write it as a multi-line statement as follows:
      !$OMP PARALLEL PRIVATE(ithr1,igpIP,Tmats,TmatB,x8H,x8Ho,u8H) &
      !$OMP& PRIVATE(v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB) &
      !$OMP& PRIVATE(genstrs,genstrn,hnmatCB,h1matCB,qlam,depsAV) &
      !$OMP& PRIVATE(sumweight,elsiz,elCvel,matCvel,Swmid,dt_el,y_Pc) &
      !$OMP& PRIVATE(aw,w_cr,iSUPG, dloc,K_chksi,K_Cheta,K_Chzeta) &
      !$OMP& PRIVATE(Porosity,rvC,Sw,Temperature,Tetaw,dspin1,Rrot) &
      !$OMP& PRIVATE(Rold,Vten,Vold,Lten,nhmatNL,epsXYZ,epsROT) &
      !$OMP& PRIVATE(sigMatNEW,initmatstif,isSolidMech)
These are lines 1138-1145 for a routine isolve.for, of a project fe_program
My compilation always fails, and I am given the following messages:
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1138): error #5082: Syntax error, found '&' when expecting one of: PRIVATE REDUCTION FIRSTPRIVATE NUM_THREADS LASTPRIVATE ORDERED SCHEDULE COLLAPSE ...
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1139): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1140): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1141): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1142): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1143): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1144): error #7844: Invalid directive.
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1145): error #7844: Invalid directive.
I tried to retain a single PRIVATE() statement, and break the lines accordingly. For example, lines 1139-1140 would be:
      !$OMP PARALLEL PRIVATE(ithr1,igpIP,Tmats,TmatB,x8H,x8Ho,u8H, &
      !$OMP& v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB, &
When I tried compiling, I got the error:
1>C:\fe_program\v4-CONSTRAINT\iSolve.for(1138): error #5082: Syntax error, found '&' when expecting one of: <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> /
I would be grateful if anyone could inform me on how to actually write the multi-line directive.
Thanks in advance!
Steve_Lionel
Take out the trailing & on the lines - that's not part of the fixed-form continuation syntax.
Ioannis_K_
Hi Steve,
Thank you very much for the prompt response! I tried your suggestion, but it did not work. The only approach that I found to work for the specific, fixed-form source file, was to create line breaks in the same way that I would for a Fortran statement:
!$OMP PARALLEL DO PRIVATE(ithr1,igpIP,Tmats,TmatB,x8H,x8Ho,u8H,
     *  v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB,
     *  genstrs,genstrn,hnmatCB,h1matCB,qlam,depsAV,
     *  sumweight,elsiz,elCvel,matCvel,Swmid,dt_el,y_Pc,
     *  aw,w_cr,iSUPG, dloc,K_chksi,K_Cheta,K_Chzeta,
     *  Porosity,rvC,Sw,Temperature,Tetaw,dspin1,Rrot,
     * Rold,Vten,Vold,Lten,nhmatNL,epsXYZ,epsROT,
     * sigMatNEW,initmatstif,isSolidMech,ennum)
Please note that the asterisks in each of the above lines are in column 6. This is the only approach for which my compiler did not complain, but I am not 100% sure that it works the way it should.... Any thoughts would be welcome.
Once again, thank you for your help,
Yannis
Steve_Lionel
Which compiler version are you using? I have a vague memory of a bug in the implementation of OMP directive continuation in fixed-form source.
Ioannis_K_
I am using Visual Fortran Compiler XE 14.0.0.103 .
Steve_Lionel
That's probably it, then. Please try a newer compiler.
jimdempseyatthecove
If you are having issues with syntax in #3, try:
!$   *  v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB,
!$   *  genstrs,genstrn,hnmatCB,h1matCB,qlam,depsAV,
!$   *  sumweight,elsiz,elCvel,matCvel,Swmid,dt_el,y_Pc,
!$   *  aw,w_cr,iSUPG, dloc,K_chksi,K_Cheta,K_Chzeta,
!$   *  Porosity,rvC,Sw,Temperature,Tetaw,dspin1,Rrot,
!$   * Rold,Vten,Vold,Lten,nhmatNL,epsXYZ,epsROT,
!$   * sigMatNEW,initmatstif,isSolidMech,ennum)
Jim Dempsey
jimdempseyatthecove
Note, the "*" is on column 6, not 6+2
Jim Dempsey
Steve_Lionel
That's not valid OpenMP syntax, however. My recollection is that the Intel documentation was wrong on this point as well.
Quoting from the OpenMP 4.0 specification:
The following sentinels are recognized in fixed form source files:
!$omp | c$omp | *$omp
Sentinels must start in column 1 and appear as a single word with no intervening characters. Fortran fixed form line length, white space, continuation, and column rules apply to the directive line. Initial directive lines must have a space or zero in column 6, and continuation directive lines must have a character other than a space or a zero in column 6.
jimdempseyatthecove
The sentinal
without omp is a conditional compile line that gets expanded when compiling with -openmp. When compiled with -openmp, in fixed form, !$ is replaced with two spaces.
!$omp on the other hand is a special variation on this in that not only does the command expand with -openmp, but due to the presence os "omp" immediately following !$, it is also a compiler directive of class OpenMP.
See IVF documentation under conditional compilation rules (Search all words: openmp continue)
Jim Dempsey
John_Campbell
New Contributor II
Jim,
I had trouble with using your example from another post using '!$' for directives. I combined your example with fixed format and required the following syntax for success. From my testing it appears that:
1)  !$  needs to be replaced by !$omp or !$omp&  for fixed format.
2)  shared(chunk_subs) appears to be required, as default(none) was specified, although fix_hack was not ?
3)  your "if" syntax worked. I also successfully ran with : fix_hack = parallel .and. (nbsubnet.gt.100)
The following adaptation of your example worked in my testing with gFortran 7.2.
I am not sure of the use of !$ in this situation.
It would be good to know what the OpenMP specification requires and what is an ifort extension. This was my 3+ try!
C  file ompc.for
C
      call try_3
      end
      subroutine try_3
      use omp_lib
      implicit none
      logical :: parallel = .TRUE.
      logical :: fix_hack
      integer, parameter :: nbsubnet = 100
      real  :: vector0(nbsubnet),vector1(nbsubnet),vector2(nbsubnet),
     +         vector3(nbsubnet),vector4(nbsubnet)
      integer :: ivector, counter_eval, chunk_subs
      integer :: i,j,k,l,m
      ivector = 100
      chunk_subs = 10
      fix_hack = parallel .and. (nbsubnet.gt.0)
      counter_eval = nbsubnet
!$omp parallel do if (fix_hack)
!$omp&         default(none)
!$omp&         shared(vector0, ivector)
!$omp&         shared(vector1, vector2)
!$omp&         shared(vector3, vector4)
!$omp&         shared(chunk_subs)
!$omp&         private(i,j,l,m)
!$omp&         reduction(+:counter_eval)
!$omp&         schedule(static,chunk_subs)
      do k=0,nbsubnet
         print *,k,omp_get_thread_num ()
         if ( omp_get_thread_num () > 0 ) counter_eval = counter_eval-1
      end do
!$omp end parallel do
      print *,'counter_eval =',counter_eval
      end subroutine try_3
jimdempseyatthecove
IVF 2017u5
Free form:
!  OpenMPContinuation.f90
    program OpenMPContinuation
    use omp_lib
    implicit none
    logical :: fix_hack
    real :: vector0(nbsubnet),vector1(nbsubnet),vector2(nbsubnet),vector3(nbsubnet),vector4(nbsubnet)
    ivector = 100
    chunk_subs = 10
!$omp parallel do default(none) if (fix_hack) &
!$             shared(vector0, ivector) &
!$             shared(vector1, vector2) &
!$             shared(vector3, vector4) &
!$             private(i,j,l,m) &
!$             reduction(+:counter_eval) &
!$             schedule(static,chunk_subs)
            do k=0,nbsubnet
                print *,k
    end do
    end program OpenMPContinuation
The above works, now testing Fixed Form
Fixed Form:
!  OpenMPContinuation.for
      use omp_lib
      implicit none
      logical :: fix_hack
      real :: vector3(nbsubnet),vector4(nbsubnet)
      ivector = 100
      chunk_subs = 10
!$   *         shared(vector0, ivector)
!$   *         shared(vector1, vector2)
!$   *         shared(vector3, vector4)
!$   *         private(i,j,l,m)
!$   *         reduction(+:counter_eval)
!$   *         schedule(static,chunk_subs)
            do k=0,nbsubnet
                print *,k
      end do
The above works.
Jim Dempsey
Steve_Lionel
There are no ifort extensions at work here. There WAS a bug in how ifort handled OpenMP directive continuation in fixed-form. That bug is not present in the 17.0 compiler but was in the 14.0 compiler.
John_Campbell
New Contributor II
Steve,
Should !$ be accepted on an OpenMP directive continuation line ?
It can produce some rather ambiguous responses from some compilers
jimdempseyatthecove
!$ is a conditional compile line that can be used on ordinary statements as well as OpenMP directives (start line) containing omp immediately following !$.
!$      integer :: iThread, nThreads
!$      iThread = omp_get_thread_num()
!$     nThreads = omp_get_num_threads()
conditionally compiles with -openmp, and treated as comment when compiled without -openmp
As to if !$ lines are continuation lines, this depends on if the statements follow standard Fortran continuation line rules (Free or Fixed).
Jim Dempsey
