I am trying to compile a fixed-form Fortran program, and I need to call a very long openMP directive. I tried to write it as a multi-line statement as follows:
!$OMP& v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB, &
I would be grateful if anyone could inform me on how to actually write the multi-line directive.
Thanks in advance!
Take out the trailing & on the lines - that's not part of the fixed-form continuation syntax.
Hi Steve,
Thank you very much for the prompt response! I tried your suggestion, but it did not work. The only approach that I found to work for the specific, fixed-form source file, was to create line breaks in the same way that I would for a Fortran statement:
Which compiler version are you using? I have a vague memory of a bug in the implementation of OMP directive continuation in fixed-form source.
I am using Visual Fortran Compiler XE 14.0.0.103 .
That's probably it, then. Please try a newer compiler.
If you are having issues with syntax in #3, try:
!$OMP PARALLEL DO PRIVATE(ithr1,igpIP,Tmats,TmatB,x8H,x8Ho,u8H, !$ * v8H,a8H,kC8H,kini8H,fC8H,mC8H,dhistCB,dhistmatCB, !$ * genstrs,genstrn,hnmatCB,h1matCB,qlam,depsAV, !$ * sumweight,elsiz,elCvel,matCvel,Swmid,dt_el,y_Pc, !$ * aw,w_cr,iSUPG, dloc,K_chksi,K_Cheta,K_Chzeta, !$ * Porosity,rvC,Sw,Temperature,Tetaw,dspin1,Rrot, !$ * Rold,Vten,Vold,Lten,nhmatNL,epsXYZ,epsROT, !$ * sigMatNEW,initmatstif,isSolidMech,ennum)
Jim Dempsey
Note, the "*" is on column 6, not 6+2
Jim Dempsey
That's not valid OpenMP syntax, however. My recollection is that the Intel documentation was wrong on this point as well.
Quoting from the OpenMP 4.0 specification:
The following sentinels are recognized in fixed form source files:
!$omp | c$omp | *$omp
Sentinels must start in column 1 and appear as a single word with no intervening characters. Fortran fixed form line length, white space, continuation, and column rules apply to the directive line. Initial directive lines must have a space or zero in column 6, and continuation directive lines must have a character other than a space or a zero in column 6.
The sentinal
without omp is a conditional compile line that gets expanded when compiling with -openmp. When compiled with -openmp, in fixed form, !$ is replaced with two spaces.
!$omp on the other hand is a special variation on this in that not only does the command expand with -openmp, but due to the presence os "omp" immediately following !$, it is also a compiler directive of class OpenMP.
See IVF documentation under conditional compilation rules (Search all words: openmp continue)
Jim Dempsey
Jim,
I had trouble with using your example from another post using '!$' for directives. I combined your example with fixed format and required the following syntax for success. From my testing it appears that:
	1)  !$  needs to be replaced by !$omp or !$omp&  for fixed format.
	2)  shared(chunk_subs) appears to be required, as default(none) was specified, although fix_hack was not ?
	3)  your "if" syntax worked. I also successfully ran with : fix_hack = parallel .and. (nbsubnet.gt.100)
The following adaptation of your example worked in my testing with gFortran 7.2.
	I am not sure of the use of !$ in this situation.
It would be good to know what the OpenMP specification requires and what is an ifort extension. This was my 3+ try!
C file ompc.for C call try_3 end subroutine try_3 use omp_lib implicit none logical :: parallel = .TRUE. logical :: fix_hack integer, parameter :: nbsubnet = 100 real :: vector0(nbsubnet),vector1(nbsubnet),vector2(nbsubnet), + vector3(nbsubnet),vector4(nbsubnet) integer :: ivector, counter_eval, chunk_subs integer :: i,j,k,l,m ivector = 100 chunk_subs = 10 fix_hack = parallel .and. (nbsubnet.gt.0) counter_eval = nbsubnet !$omp parallel do if (fix_hack) !$omp& default(none) !$omp& shared(vector0, ivector) !$omp& shared(vector1, vector2) !$omp& shared(vector3, vector4) !$omp& shared(chunk_subs) !$omp& private(i,j,l,m) !$omp& reduction(+:counter_eval) !$omp& schedule(static,chunk_subs) do k=0,nbsubnet print *,k,omp_get_thread_num () if ( omp_get_thread_num () > 0 ) counter_eval = counter_eval-1 end do !$omp end parallel do print *,'counter_eval =',counter_eval end subroutine try_3
IVF 2017u5
Free form:
!  OpenMPContinuation.f90
    program OpenMPContinuation
    use omp_lib
    implicit none
    logical :: fix_hack
    real :: vector0(nbsubnet),vector1(nbsubnet),vector2(nbsubnet),vector3(nbsubnet),vector4(nbsubnet)
    ivector = 100
    chunk_subs = 10
!$omp parallel do default(none) if (fix_hack) &
!$             shared(vector0, ivector) &
!$             shared(vector1, vector2) &
!$             shared(vector3, vector4) &
!$             private(i,j,l,m) &
!$             reduction(+:counter_eval) &
!$             schedule(static,chunk_subs)
            do k=0,nbsubnet
                print *,k
    end do
    end program OpenMPContinuation
The above works, now testing Fixed Form
Fixed Form:
!  OpenMPContinuation.for
      use omp_lib
      implicit none
      logical :: fix_hack
      real :: vector3(nbsubnet),vector4(nbsubnet)
      ivector = 100
      chunk_subs = 10
!$   *         shared(vector0, ivector)
!$   *         shared(vector1, vector2)
!$   *         shared(vector3, vector4)
!$   *         private(i,j,l,m)
!$   *         reduction(+:counter_eval)
!$   *         schedule(static,chunk_subs)
            do k=0,nbsubnet
                print *,k
      end do
The above works.
Jim Dempsey
There are no ifort extensions at work here. There WAS a bug in how ifort handled OpenMP directive continuation in fixed-form. That bug is not present in the 17.0 compiler but was in the 14.0 compiler.
Steve,
Should !$ be accepted on an OpenMP directive continuation line ?
	It can produce some rather ambiguous responses from some compilers
!$ is a conditional compile line that can be used on ordinary statements as well as OpenMP directives (start line) containing omp immediately following !$.
!$      integer :: iThread, nThreads
	!$      iThread = omp_get_thread_num()
	!$     nThreads = omp_get_num_threads()
conditionally compiles with -openmp, and treated as comment when compiled without -openmp
As to if !$ lines are continuation lines, this depends on if the statements follow standard Fortran continuation line rules (Free or Fixed).
Jim Dempsey
