Trouble with naming a module
Navdeep_Rana
I have a stupid problem, and most probably I have messed something up but hear me out.
I have a module of form
module linear_stability
    real(kind=8), pointer :: curl_p1
end module linear_stability
Which when I try to use in a programme spits out
error #7013: This module file was not generated by any release of this compiler.
error #6404: This name does not have a type, and must have an explicit type.   [CURL_P1]
Similarly openmpi-gfortran throws
Error: Symbol 'curl_p1' at (1) has no IMPLICIT type
However if I change the module name to linear_stability1 or something else, it compiles without any errors.
I have not defined the module or used linear_stability name anywhere else and I don't think any such module exists anywhere on my system. I am clueless as why it is happening.
Ideas people?
Juergen_R_R
Valued Contributor II
I think you do not give enough information here. Does the error appear when compiling the module above, or does it appear when compiling your main program which includes this module? I would suspect the latter. And then I am pretty sure that there is somewhere a linear_stability.mod lying around.
Navdeep_Rana
The error appears later, while compiling the main. Found it. As you said there was a .mod file lying around!
It was generated by a linting plugin for vim. I was being stupid.
