- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I am trying to run the install script to upgrade my Fortran compiler install and cannot because the install script fails with the above error . I double checked to make sure that I had download the proper Intel 64 architecture, Has licensing changed since I bought my product? I need to get to at least update 5 to resolve an MPI bug. Any pointers would be most appreciated. Thanks.
- Marcas:
- Intel® Fortran Compiler
1 Solução
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Are you using a virtual machine, by any chance? Please show the output of:
cat /proc/cpuinfo
You can get around this by editing the install script - the check appears in two places. It is intended to ensure that the CPU supports a minimum of SSE2 (Pentium 4). We have seen some users installing with VMs that identify themselves as Pentium, which would trigger this issue.
cat /proc/cpuinfo
Link copiado
6 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Please show the output of uname -a Licensing has not changed. Please also show the full filename of the installer you downloaded.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Here is the output you requested:
# uname -a
# uname -a
Linux research.cluster 2.6.32-71.7.1.el6.x86_64 #1 SMP Mon Jun 27
07:24:50 BST 2011 x86_64 x86_64 x86_64 GNU/Linux
Files that I downloaded from my registerd product list that were available:
# ls
l_fcompxe_intel64_2011.10.319.tgz
l_mkl_10.3.10.319_intel64.tgz
l_mpi_p_4.0.3.008.tgz
Then I uncompressed/untarred the composer tarball first, and tried to run the install.sh script and got the "CPU is not supported" error.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Very odd. I will ask someone else to take a look at this as I'm not sure where to go from here. For what it's worth, you don't need the mkl installer as fcompxe includes that version.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
cat /proc/cpuinfo
cat /proc/cpuinfo
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Steve, Thank you very much. I am indeed running this on a VM and the /proc/cpuinfo is misleading to the install script. I was able to edit out the CPU check in the install script and get everything to install properly. Even though I had the current MPI update already installed, I uninstalled and then reinstalled the sotware so that it points to the updated compiler install. I greatly appreciate your expert help in resolving this problem.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You're welcome. Glad to know you got it straightened out.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
