Unable to use VS2022 + ifx
Ward
Try as I might I could not get it to work with the Visual Studio 2022.
From the command line it says cannot find ifx.
From Visual Studio I run Build Solution it makes an executable that can't run.
Is there a way I can use ifort somewhere it was so much easier.
andrew_4619
Was the command line in a CMD window created by the start menu oneapi Fortran shortcut. In Vs what does the build log look like, post it.
Devorah_H_Intel
Follow the steps listed in https://www.intel.com/content/www/us/en/docs/fortran-compiler/get-started-guide/2025-0/get-started-on-windows.html  - a good place to start to resolve the issues you are having.
