29341 Discussions
side-effects in internal pure procedures not reported by the compiler
riad_h_1
Dear,
a probable bug in ifx: in the following example, a pure internal procedure modifies a variable of its parent subroutine.
ifx fails to report this side effect (see also the discussion at https://fortran-lang.discourse.group/t/internal-pure-procedure-with-side-effect/8974).
Thank you.
module foo_m
   implicit none
contains
   subroutine foo ( a, b )
      integer, intent(in out) :: a, b
      b = 0
      call sbar ( a )
      b = fbar ( a )
   contains
      pure subroutine sbar ( a )
         integer, intent(out) :: a
         a = b
         b = 1 ! <- the compiler should report this error
      end subroutine sbar
      pure function fbar ( a ) result( r )
         integer, intent(in) :: a
         integer             :: r
         r = a+b
         b = 2 ! <- same here
      end function fbar
   end subroutine foo
end module foo_m
TobiasK
@riad_h_1
thanks for reporting that, I agree that should not happen. I escalated this to our dev team
