29419 Discussions
Unexpected "warning #7026: Non-standard extension" for a parameterized derived type with type-bound procedures.
FortranFan
This builds on the code snippet in Quote #2 in the topic:  https://software.intel.com/en-us/forums/topic/536577.  Compiler 15, Update 1 gives "warning #7026: Non-standard extension." with /stand:f08.  To me, this is unexpected.  Comments?
MODULE m
   USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : I4 => INT32, SP => REAL32, DP => REAL64
   IMPLICIT NONE
   PRIVATE
   PUBLIC :: I4, SP, DP
   TYPE, PUBLIC :: t(k,n)
      PRIVATE
      INTEGER(I4), KIND :: k = SP
      INTEGER(I4), LEN  :: n = 1
      REAL(k) :: m_X(n)
   CONTAINS
      PRIVATE
      PROCEDURE, PASS(This) :: GetX_SP
      PROCEDURE, PASS(This) :: GetX_DP
      PROCEDURE, PASS(This) :: SetX_SP
      PROCEDURE, PASS(This) :: SetX_DP
      GENERIC, PUBLIC :: X => GetX_SP, GetX_DP
      GENERIC, PUBLIC :: SetX => SetX_SP, SetX_DP
   END TYPE t
CONTAINS
   PURE FUNCTION GetX_SP(This) RESULT(RetVal)
      CLASS(t(SP,*)), INTENT(IN) :: This
      !.. Function result
      REAL(SP), ALLOCATABLE :: RetVal(:)
      RetVal = This%m_X
      RETURN
   END FUNCTION GetX_SP
   PURE FUNCTION GetX_DP(This) RESULT(RetVal)
      CLASS(t(DP,*)), INTENT(IN) :: This
      !.. Function result
      REAL(DP), ALLOCATABLE :: RetVal(:)
      RetVal = This%m_X
      RETURN
   END FUNCTION GetX_DP
   PURE SUBROUTINE SetX_SP(This, Arr)
      CLASS(t(SP,*)), INTENT(INOUT) :: This
      REAL(SP), INTENT(IN)          :: Arr(:)
      IF (SIZE(Arr) == This%n) THEN
         This%m_X = Arr
      END IF
      RETURN
   END SUBROUTINE SetX_SP
   PURE SUBROUTINE SetX_DP(This, Arr)
      CLASS(t(DP,*)), INTENT(INOUT) :: This
      REAL(DP), INTENT(IN)          :: Arr(:)
         This%m_X = Arr
      END IF
      RETURN
   END SUBROUTINE SetX_DP
END MODULE m
------ Build started: Project: TestFor, Configuration: Debug|Win32 ------
Compiling with Intel(R) Visual Fortran Compiler XE 15.0.1.148 [IA-32]...
TestMod.f90
C:\..\TestMod.f90(56): warning #7026: Non-standard extension.   [T#4&*]
C:\..\TestMod.f90(69): warning #7026: Non-standard extension.   [T#8&*]
Build log written to  "file://C:\..\Debug\Win32\TestForBuildLog.htm"
TestFor - 0 error(s), 2 warning(s)
---------------------- Done ----------------------
We've seen this one before - I'll check it out in more detail on Monday.
I believe that any standards warning here is unwarranted. We have other reports of this diagnostic coming out for uses of PDTs. I have escalated it as issue DPD200363879.
I expect this to be fixed in Update 2, planned for February, as part of a set of fixes for PDTs.
FortranFan
Excellent news Steve.  I look forward to the update.
