I am hoping someone can provide insight into this particular message beyond what the documentation provides:
forrtl: severe (152) unresolved contention for Intel Fortran RTL global resource
This seems to indicate that the system is having trouble handling multiple calls to IO routines from the individual threads -- that is, the routines are not capable of handling threaded IO calls. This reminds me of something I read about using CRITICAL declarations to isolate IO calls.
I am wondering about the level of granularity I need to use for this protection. Is it sufficient to isolate calls to an individual file, or must Iisolate all IO calls to all files? Or does it depend on the call: do I need to isolate all READ calls from each other and all WRITE calls from each other, but can permit Thread 0 to READ while Thread 3 WRITEs?
And are there other considerations I'm missing?
The Fortran RTL can protect itself against access from multiple threads assuming that the /reentrancy:threaded option is used (I'm pretty sure /Qopenmp enables that.) However, the languge disallows starting an I/O on a given unit while another one is in progress on that unit, hence the usual advice to put I/O in a critical section (or a single thread).
Thanks, Steve.
The program is a single EXE and uses the IMSL ('link_fnl_static.h') library and the OMP ('libiomp5md.lib') library.
The command line I've been using reads:
/nologo /debug:full /Od/gen-interfaces /Qopenmp /Qdiag-error-limit:50 /Qopenmp_report:2 /warn:interfaces /Qauto /align:commons /assume:byterecl /fpe:0 /names:uppercase /module:"x64Debug" /object:"x64Debug" /asmattr:source /asmfile:"x64Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c
I set the /reentrancy:threaded option, but that produced similar results:one /0 error, one unresolved contention, and one "internal consistency check failure, file for_exit_handler.c, line 359".
Which leads me to another question: what happens after a fatal error on one thread? Does the system terminate them (unless they suicide first)? Or do the survivors get to run as long as they can?
In the most recent case, three (of four) threads end with out-of-bound subscript errors. The RTL throws up an address stack for each error, and the three threads stop printing their "here I am" messages. The fourth thread putters on contentedly, spitting out messages and writing to the TX file. (This lead to my question about how RTL handles shutting down threads.) The last thread then croaks with errmsg #25, record number outside range, while writing to the IX file. The file was opened with the default "unlimited" number of records, so the applicability of this message seems, um, uncertain. I have no problem with this being an artifact of RTL shutting the thread down, but it would be nice to know I don't have to worry about errmsg #25.
Yes, sorry, should have mentioned that.
I expect that RTL is in the process of shutting down thread four, but thread four is prosecuting output. So while RTL's left hand kills the thread, RTL's right hand goes to do output but fails because the left hand wiped some needed parameter. Thread four did nothing wrong, but its demise rippled.
Steve Lionel (Intel) wrote:Hi Steve, I have a similar problem: http://software.intel.com/en-us/forums/topic/335328 What do you mean by "putting I/O in a critical section"? Thanks in advance, MarkusThe information I received said that this can happen if two threads are trying to do I/O to the same unit number at the same time, and the RTL is having difficulty getting access to the data structure. This would be an error anyway, hence my suggestion to put I/O in a critical section. Is this happening after some other error occurs in the program?
I still get this error. But it still happens even when it is in a CRITICAL section:
[fortran]
subroutine writeReportTemperatures()
use globaleVariablen
use EA_Telegramm
implicit none
character*1 seperator
character*512 tempstring
integer(kind=4) iUnit
!$OMP CRITICAL (TEMP_ACCESS)
seperator=';'
write(tempstring,'(3(a,i2.2),8(a,f6.1))') &
seperator,EA_Telegramm_849%DBX340,':',EA_Telegramm_849%DBX360,':',EA_Telegramm_849%DBX380, &
seperator,tempStrang(1,1,nzTempGiessmaschine), &
seperator,measuredValues849%tempGiessmaschine, &
seperator,tempStrang(1,1,nzTempMRGS), &
seperator,measuredValues849%tempMRGS, &
seperator,tempStrang(1,1,nzTempTreiber1), &
seperator,measuredValues849%tempTreiber1, &
seperator,tempStrang(1,1,nzTempTreiber2), &
seperator,measuredValues849%tempTreiber2
call replaceChar(tempstring,'.',',')
open(NEWUNIT=iUnit, file=trim(fileNameReportTemperatures), status='old', access='append')
write(iUnit,'(a)') trim(tempstring)
close(iUnit)
!$OMP END CRITICAL (TEMP_ACCESS)
end subroutine writeReportTemperatures
[/fortran]
The "forrtl: severe (152): unresolved contention for Intel Fortran RTL global resource" error still occurs, sometimes in the longer write statement to tempstring, sometimes in the write statement to iUnit and sometimes in the close statement.
When I replace the newunit=iunit to a fixed unit number the same happens. This file is only being used in this subroutine and in a initReportTemperatures subroutine, they can´t be called at the same time. Performing a flush(iUnit) was useless too.
Markus
Does the error happen on its own? Most of the time I see this when my program is in the process of crashing and burning due to other unrelated incompetence on my part.
p.s. filenames for open are "auto-trimmed" - trailing blanks are not used.
How was tempstring opened? In particular was asychronous used?
Jim Dempsey
IanH wrote:
Does the error happen on its own? Most of the time I see this when my program is in the process of crashing and burning due to other unrelated incompetence on my part.p.s. filenames for open are "auto-trimmed" - trailing blanks are not used.
The program doesn´t crash when I don´t call the writeTemperatures subroutine. I have it running for nearly 30 minutes, with the call it never ran longer than 2 minutes.
Markus
PS: Thanks for the trim information in the open statement.
jimdempseyatthecove wrote:
How was tempstring opened? In particular was asychronous used?Jim Dempsey
I quite don´t understand your question. tempstring is a local character*512 variable.
If you mean if the file was opened with asynchronous='yes': This was not the case. Opening the file with asynchronous='yes' leads to some kind of dead lock. At different run times the program does nothing any more. But it is not freezed and it is not "not repsonding" when looking into Windows Taskmanager.
Markus
If you read some of the other threads you will note that there is (was) an issue where when the number of pending asynchronous I/O's exceed an internal limit that this induces an I/O error. You are not using asynchronous='yes' so this eliminates that problem (this is why I asked). There was another old issue where NEWUNIT= crapped out after some number of iterations. You indicate that by using fixed unit number you still experience the crash. So NEWUNIT= is not the issue. You've demonstrated that these two potential issues are not the proble. What do we have left....
1) This is an embarrassing reason: The .obj containing writeReportTemperatures was not compiled with -openmp. This would cause the !$OMP CRITICAL to be ineffective. Note, should this subroutine be in a module it is not unusual for a module not to get compiled (or compilation errors) and/or for module path for linking not same as module path for outputs. In these cases an out of date or wrong .obj is linked. Verify this. Also note, verification in Debug build is not verification in Release build.
2) There is a resource error. What happens when each thread uses a unique filenameReportTemperatures file name. Careful omp_get_thread_num not necessarily thread unique when using nested parallel regions, use thread ID instead (or unique number obtained and saved in thread private variable). Should this fix the issue, then the problem lies within the O/S.
3) There is a resource error (2). What happens if the open for filenameReportTemperatures is performed once for all threads, and then you use only the WRITE within your subroutine? Windows has a Lazy write which may be causing an issue when performing open, append, close, open, append, close...
4) Is the output file for filenameReportTemperatures in one of the Windows folders (or sub folder)? If so, create a different folder (path) that is not under a Windows system folder.
Jim Dempsey
1.) The subroutine is part of the main program and not inside a module. Clean and Rebuild / Deleting the obj. per hand doesn´t help.
2.) The creation of the file (in a subroutine initReportTemperatures) is prior to the first call of writeReportTemperatures. They are not in different threads, they are beeing called in the same subroutine:
[fortran]
! ... some other code
if(bReportTemperaturen.eqv..true.) then
call initReportTemperatures()
end if
do while (programRuns.eqv..true.)
!... some other code
call writeReportTemperatures()
end if
[/fortran]
3.) To prevent a open - append - write - close - open ... I/O problem I tried flush(iUnit), but this didn´t help either.
4.) The file is in my C:\User\ directory so I have full access to that file.
I think that the error is somewhere else in my code and has nothing to do with this statements...
Markus
RE 2)
Lift the OPEN and CLOSE for filenameReportTemperatures out of subroutine writeReportTemperatures, using say iUnitReportTemperatures, keeping only the WRITE(iUnitReportTemperatures, ... in subroutine writeReportTemperatures. You may want to add flush(iUnitReportTemperatures) after WRITE if desired. IOW:
program, open/init, append, append, append, ..., append, close, end program
Have you run your code in Debug build, with OpenMP enabled, and with all runtime checks enabled (uninitialized variables, array index checking, etc...). I've experienced situations where such errors in coding cause seamingly unrelated errors in different code.
I just have to ask: Shouldn't iUnit be assigned a value at some point? At this point I wouldn't be sure that the two routines are writing to the same file.
