Received the following diagnostic error:
"error #12306: unvalidated value is received from call to an external function at (file:sqp_MAP.f line:283) which can be used in loop condition expression"
Can you provide anexample for precisely how one should go about validating a value before using it in a loop condition expression?
Michael Cupples
Michael Cupples
Would I be correct in assuming that you enabled the "Source Checker" diagnostics to get this message? Can you show the call, declaration of the arguments, and the called function and use line?
PS.
The error messages that I provided in the previous reply were generated in 11.1,067. I am using MS Visual Studio 2008 Standard.
Michael Cupples
Michael Cupples
Topic Options
