Upgraded to Visual Studio 2010
davidgraham
I've just updated to Visual Studio 2010 Full, before I was on Visual Studio 2008 shell.
With Visual Studio 2008 shell I had to use the program 'ResEdit' to edit the resouce file - to edit the dialogs etc.
With Visusal Studio 2010 full I should be able to edit the dialogs directly - how do I do this, back in VF6.6 there was a resource tab.
Also how do I get the watch window to be displayed when debugging - I can't see anything that looks like it, just an 'immediate' window.
I'm sure the answers are simple its just getting used to the new terminology.
David
davidgraham
Update - I've found the Watch Window, but not fow to edit the dialogs.
With full VS2010, and the Visual C++ component installed, you should be able to edit dialogs. You're sure you're in the VS2010 environment? Did you do a default install of VS2010 before installing Intel Fortran?
davidgraham
I didn't install Visual C++ (I did install Visual Basic).
Is all I need to do is add Visusal C++?
David
Yes - you should have received a warning when you installed Fortran if it did not find Visual C++. I suggest that you uninstall Fortran, install the Visual C++ component, then reinstall Fortran.
davidgraham
I removed Visual Fortran, installed C++ for Visusal Sudio 2010 and reinstalled Visual Fortran 2011.
Where do I edit the dialogs?
Should I have upgraded my Visual Fortran project again?
David
You should be able to just double-click on the .rc file and that should bring up the resource editor.
davidgraham
When I double click on the rc file I get the mesage "fatal error RC1015: cannot open include file 'windows.h'"
davidgraham
Previously when I used Vuisual Studio 2008 Express I had to use ResEdit to edit the dialogs.
I wonder if the format of the rc file is slightly different.
The problem now is that the folder containing the Windows SDK .h files is not in the Includes path. This ought to have been set up when Visual C++ got installed, but some customers find it didn't. Maybe the order in which you did the install contributed to the problem.
Find the folder on your system containing windows.h. It is possibly C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\ Add this to the list in Tools > Options > Intel Visual Fortran > Compilers > Includes.
davidgraham
The include files are:
$(IFortInstallDir)compiler\include
$(IFortInstallDir)compiler\include\ia32
$(IFortInstallDir)mkl\include
$(VCInstallDir)atlmfc\include
$(VCInstallDir)include
$(WindowsSdkDir)include
$(FrameworkSDKDir)include
The .h files are in
I'm not sure what I actually add.
It's the $(WindowsSdkDir) definition which is the problem. It comes from a registry entry which may not be correct. You can look at HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SDKs\Windows to see if CurrentInstallDir matches what you found above. It should. Otherwise, just add that folder to the list for Includes.
davidgraham
Sorry, I've tried various combinations but still cannot get it to work.
I'm worried incase I mess someting up.
The registry entry is:
has c:\program Files\Microsoft SDKs\Windows\v7.1
There are also directores for v6.0A, v7.0A & v7.1, they contain
c:\program Files\Microsoft SDKs\Windows\v6.0A
c:\program Files\Microsoft SDKs\Windows\v7.0A and
c:\program Files\Microsoft SDKs\Windows\v7.1 respectively
The project properties compile includes are:
The windows.h is in:
C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Include
and also at
C:\Program Files\Microsoft SDKs\Windows\v7.1\Include
Maybe the registry entries should be "Program Files (x86)" rather than "Program Files".
The different versions of the SDK install in different places. Just put:
in the Includes list in Visual Studio.
davidgraham
I have tried that and I still get the same error.
Where do you get the error? When you try to open the resource file? This suggests to me that the registry entry for the Windows SDK is incorrect.
davidgraham
I get the error when I double click in the .rc file.
I gave the registry entries in a previous reply - but there are several - local machine, current machine and different versions.
What do you have in HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Microsoft SDKs\Windows (if you are on an x64 system)?
What about HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SDKs\Windows ?
davidgraham
Here are the entries of the registry:
C:Program Files\Microsoft SDKs\Windows\v7.1\
There should be four values under that key, (Default), CurrentInstallFolder, CurrentVersion and ProductVersion.
You could try this. Uninstall Fortran. Do a "Repair" on VS2010 from Programs and Features, then reinstall Fortran. Or you can download and install a recent Windows SDK which might correct the problem.
davidgraham
Yes there are 4 values:
for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SDKs\Windows:
Default - not set
CurrentInstallFolder : c:\programfiles\Microsoft SDKs\Windows\v7.1\
Current Version : v7.1
Product version : v6.0A
for HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Microsoft SDKs\Windows:
it is the same.
I will reinstall Fortran tomorrow unless you suggest otherwise.
