Use memcpy, mmap, munmap, shm_open & shm_unlink with fortran
Stephan_D_
I have to port a windows fortran project to linux. The windows version uses CreateFileMapping,OpenFileMapping,MapViewOfFile and CopyMemory.
After some search I found, that linux has something similar with mmap and shm_open. Also I could use memcpy on both platforms.
My problem is that memcpy only works on windows and I always get undefined reference when I try to use shm_open for example. I guess I'm missing some compiler flags and/or using the wrong syntax for the external routines?
Here a little code example:
      module test
	  integer,parameter :: PROT_READ=1
      integer,parameter :: PROT_WRITE=2
      integer,parameter :: MAP_PRIVATE=2
      integer,parameter :: MAP_SHARED=1
      integer,parameter :: O_RDONLY=0
      integer,parameter :: O_WRONLY=1
      integer,parameter :: O_RDWR=2
      integer,parameter :: O_ACCMODE=3
      integer,parameter :: O_CREAT=512
      integer,parameter :: O_EXCL=2048
      integer,parameter :: O_TRUNC=1024
      integer,parameter :: S_IRUSR=1024
      integer,parameter :: S_IWUSR=512
      integer,parameter :: S_IXUSR=256
      integer,parameter :: S_IRGRP=64
      integer,parameter :: S_IWGRP=32
      integer,parameter :: S_IXGRP=16
      integer,parameter :: S_IROTH=4
      integer,parameter :: S_IWOTH=2
      integer,parameter :: S_IXOTH=1
      integer,parameter :: S_ISUID=16384
      integer,parameter :: S_ISGID=8192
	  interface
	  subroutine  memcpy(dest, src, n) bind(C,name='memcpy')
      use iso_c_binding
      INTEGER(c_intptr_t), intent(in):: dest
      INTEGER(c_intptr_t), intent(in):: src
      integer(c_size_t), value :: n
      end subroutine memcpy
	  end interface
	  interface
      INTEGER(c_intptr_t) function mmap(addr,len,prot,flags,fildes,off) bind(c,name='mmap')
      use iso_c_binding
      integer(c_int), value :: addr
      integer(c_size_t), value :: len
      integer(c_int), value :: prot
      integer(c_int), value :: flags
      integer(c_int), value :: fildes
      integer(c_size_t), value :: off
      end function mmap
      end interface
      interface
      integer(c_int) function munmap(addr, len) bind(c,name='munmap')
      use iso_c_binding
      end function munmap
      end interface
      interface
      integer(c_int) function shm_open(name,oflag,mode) \
	  bind(c,name='shm_open')
      use iso_c_binding
      character(kind=c_char) :: name(*)
      integer(c_int), value :: oflag
      integer(c_int16_t), value :: mode
      end function shm_open
      end interface
      interface
      integer(c_int) function shm_unlink(name) bind(c,name='shm_unlink')
      use iso_c_binding
      end function shm_unlink
      end interface
	  end module
	  program FortranTest
	  use iso_c_binding
	  use test
      implicit none
      real*8, allocatable, dimension(:) :: testarr, testarr2
      integer :: i, oflag, sflag
	  oflag = ior(O_RDWR, O_CREAT)
	  sflag = ior(S_IWUSR, S_IRUSR)
	  i = shm_open('/home/lbb/FEAP/test/test123.blub', oflag, sflag)
      allocate(testarr(10))
	  allocate(testarr2(10))
      do i=1,10
      testarr(i) = 1
	  testarr2(i) = 2
      end do
	  print *, 'testarr'
	  do i=1,10
      print *, testarr(i)
      end do
	  print *, 'testarr2'
	  do i=1,10
      print *, testarr2(i)
      end do
	  print *, 'call memcpy'
	  call memcpy(loc(testarr(1)), loc(testarr2(1)), 16)
	  print *, 'testarr'
	  do i=1,10
      print *, testarr(i)
      end do
      read (*,*)
      end program FortranTest
The makefile looks like this:
# fortran compiler = intel fortran
fcomp = ifort
switch = -module obj -w -f77rtl -fpp -qopenmp -parallel -intconstant -zero -assume:byterecl -check:pointers -check:bounds -check:uninit
baseList = test2.for
baseObj = $(baseList:.for=.o)
all: base test
base: $(baseObj)
%.o: %.for
	$(fcomp) $(switch) -c $< -o obj/$(notdir $@)
test: base
	$(fcomp) $(switch) obj/*.o -o obj/test2 -mkl -shared-libgcc -threads -cxxlib
clean:
	@echo "target clean: delete obj/*"
	rm -f obj/*
If I run this example (without shm_open) on windows I get the expected result:
testarr
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
 testarr2
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
 call memcpy
 testarr
   2.00000000000000
   2.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
On linux I get :
lbb@dev-01:~/FEAP/test$ obj/test2
 testarr
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
 testarr2
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
   2.00000000000000
 call memcpy
 testarr
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
   1.00000000000000
So memcpy isn't working as expected (maybe the c function isn't called at all?)
So any hints for me?
Kind regards,
Stephan
Steve_Lionel
You need VALUE on the dest and src arguments in the interface to memcpy.
Stephan_D_
Thank you Steve.
In my last attempt I had "INTEGER(c_intptr_t), intent(in), value:: dest"
This worked on windows. After removing the "intent(in)" it works on both. Adding '-lrt' fixes the undefined reference error. I can now create a file with the correct size in /dev/shm. But it always contains zero. I guess I didn't understand how the different pointer types in fortran/c work. Any hints?
My current example:
      module test
	  ! O_CREAT | O_RDWR
	  integer, parameter :: ocreate = 66
	  ! O_RDONLY
	  integer, parameter :: oread = 0
	  ! PROT_READ | PROT_WRITE
	  integer, parameter :: preadwrite = 6
	  ! MAP_SHARED
	  integer, parameter :: mshare = 8
	  ! file permissions 0666
	  integer, parameter :: fperm = 438
	  interface
      use iso_c_binding
      INTEGER(c_intptr_t), value:: dest
      INTEGER(c_intptr_t), value:: src
	  end interface
	  interface
      INTEGER(c_intptr_t) function mmap(addr,len,prot, \
      use iso_c_binding
      end function mmap
      end interface
      interface
      integer(c_int) function munmap(addr, len) \
      use iso_c_binding
      end function munmap
      end interface
      interface
      integer(c_int) function ftruncate(fd, len) \
	  bind(c,name='ftruncate')
      use iso_c_binding
      integer(c_int), value :: fd
      end function ftruncate
      end interface
	  interface
      integer(c_int) function close(fd) \
	  bind(c,name='close')
      use iso_c_binding
      end function close
      end interface
      interface
      use iso_c_binding
      end interface
      interface
      integer(c_int) function shm_unlink(name) \
      use iso_c_binding
      end interface
	  end module
	  program FortranTest
	  use iso_c_binding
	  use test
      implicit none
	  INTEGER(c_intptr_t) :: adr
	  integer :: i, fd
      do i=1,10
      testarr(i) = i
      end do
	  fd = shm_open('test123', ocreate, fperm)
	  if(fd == -1) stop 'shm_open error'
	  i = ftruncate(fd, 80)
	  if(i == -1) stop 'ftruncate error'
	  adr = mmap(0, 80, preadwrite, mshare, fd, 0)
	  print *, 'call first memcpy'
	  call memcpy(loc(adr), loc(testarr), 80)
	  i = munmap(adr, 80)
	  if(i == -1) stop 'munmap error'
	  i = close(fd)
	  if(i == -1) stop 'close error'
!	  i = shm_unlink('test123')
!	  if(i == -1) stop 'shm_unlink error'
Steve_Lionel
I can make only a general comment here. You declare the dest and src arguments to memcpy as address-sized integers, not pointers in the Fortran sense. memcpy wants to see the address of the dest and src by value in the argument list, so that's why you need VALUE as otherwise Fortran would pass the integer (that contains an address) itself by reference (address of an address). INTENT would have absolutely no effect on how it was passed.
I suggest stepping through the code in the debugger and make sure that all the arguments have the correct values as you go. However, I do see something that raises a red flag - you declare the "addr" argument to mmap and munmap as integer(c_int). This is absolutely wrong - use integer(c_intptr_t) instead. On Linux you are almost certainly on a 64-bit system and using an int for the address will result in errors.
Stephan_D_
Thank you. I got it now. For anyone who might need the same here the working code:
      module test
	  ! O_CREAT | O_RDWR
	  ! O_RDONLY
	  integer, parameter :: preadwrite = 3
	  ! PROT_READ
	  integer, parameter :: pread = 1
	  ! MAP_SHARED
	  integer, parameter :: mshare = 1
	  ! S_IRUSR | S_IWUSR
	  integer, parameter :: fperm = 384
	  interface
      use iso_c_binding
	  end interface
	  interface
	  flags,fildes,off) result(result) bind(c,name='mmap')
      use iso_c_binding
      INTEGER(c_intptr_t), value :: addr
      end function mmap
      end interface
      interface
      use iso_c_binding
      end function munmap
      end interface
      interface
      use iso_c_binding
      end interface
	  interface
      use iso_c_binding
      end function close
      end interface
      interface
      use iso_c_binding
      end interface
      interface
      use iso_c_binding
      end interface
	  end module
	  program FortranTest
	  use iso_c_binding
	  use test
	  use ifport
      implicit none
	  integer :: i, fd, err
      do i=1,10
      testarr(i) = i
      end do
	  if(i == -1) then
	  err = GetLastError()
	  print *, err
	  end if
	  adr = mmap(loc(0), 80, preadwrite, mshare, fd, 0)
	  if(adr == -1) then
	  print *, err
	  stop 'mmap error'
	  endif
	  print *,'adress:',loc(adr)
	  print *,'adress:',adr
	  call memcpy(adr, loc(testarr), 80)
	  i = munmap(adr, 80)
	  i = close(fd)
	  fd = shm_open('test123', oread, fperm)
	  adr = mmap(loc(0), 80, pread, mshare, fd, 0)
	  if(adr == -1) then
	  print *, err
	  stop 'mmap error'
	  endif
	  print *, 'call second memcpy'
	  call memcpy(loc(testarr2), adr, 80)
	  i = munmap(adr, 80)
	  i = close(fd)
	  do i=1,10
	  end do
