Hi everyone,
Could anyone describe the differences in using TYPE or CLASS in declarations or in SELECT TYPE statements?
Also, I can not get type bound procedures to work if I use the PASS option, only NOPASS works.
Does anyone else have the same problem?
The compiler is ifort 11.1.051.
From 8.1.5.2 of the standard:
Within the block following a TYPE IS type guard statement, the associating entity (16.4.5) is not
polymorphic (5.1.1.2), has the type named in the type guard statement, and has the type parameter
values of the selector.
Within the block following a CLASS IS type guard statement, the associating entity is polymorphic and
has the declared type named in the type guard statement. The type parameter values of the associating
entity are the corresponding type parameter values of the selector.
Thanks for the answer.
I have another question regarding TYPE or CLASS.
I made a program containg the type MAALER with the extensions TERMOMETER, BAROMETER and VINDMAALER. All these types have type bound procedures. First I made them with the NOPASS attribute.
This worked well. Then I changed to PASS. To get this to work I had to change from
TYPE(TERMOMETER) to CLASS(TERMOMETER) and so on in all the procedures of the extended types.
Is this according to the standard or a bug?
The program is attached.
What went wrong when you tried it? This program compiles and runs with 11.1.065.
4.5.3.3 The passed-object dummy argument
C453 The passed-object dummy argument shall be a scalar, nonpointer, nonallocatable dummy dataobject with the same declared type as the type being defined; all of its length type parametersshall be assumed; it shall be polymorphic (5.1.1.2) if and only if the type being defined isextensible (4.5.6).
4.5.6 Type extension
A nonsequence derived type that does not have the BIND attribute is an extensible type.- Mark as New
The OP's question boils down to this:
[fortran]module M9 type t real ::a contains procedure, pass(arg) :: foo procedure, pass(arg) :: bar end type t contains subroutine bar(arg) class(t), intent(in) :: arg !OK; polymorphic end subroutine subroutine foo(arg) type(t), intent(in) :: arg !non-standard? ifort complains about not being polymorphic end subroutine end module [/fortran]This example is adapted from page 97 of "The Fortran 2003 Handbook". Which shows using type(x) instead of class(x) for TBP dummies when no polymorphism is actually involved. Either the book is wrong or the compiler is wrong.
{I think this topic may have been discussed before.}
Page 89 of the handbook gives the rules and restrictions for passed-object dummy argument. Rule 6 last line says: "It must be polymorphic (5.2) if and only if the type is extensible (4.4.12)." (I have made extensible bold.)
Section 4.4.12, page 100, paragraph 2, first line: Any derived type that is neither a sequence nor a bind type is extensible.
Hence, I think, keyword class should be used in the example on page 97.
Abhi
Abhi
Right--same rules as I posted from the standard above. I tend to agree the book is wrong. Anyways it's easy to just use class and forget about it :)
Hi Steve,
The attached version compiles. If you change from CLASS to TYPE in the routines SETT_TEMPERATUR, SETT_TRYKK and so on it fails on my compiler.
Hi Joseph,
Thanks, this is exactly the point.
Svein
Svein
Topic Options
