User defined derived-ype IO for extended type
Dong_Zheng
I'd like to add user defined derived-type IO for an extended type. However I got an error message "error #8638: The type/rank signature for arguments of this specific subroutine is identical to another specific subroutine that shares the same defined I/O." Anyone has idea how to do this? The test code is here. module mymod type :: mydata_t character(len=10) :: name contains procedure :: write_unfmt_mydata generic :: write(unformatted) => write_unfmt_mydata end type mydata_t type, extends(mydata_t) :: myint_t integer :: nn integer, pointer :: xx(:) contains procedure :: write_unfmt_myint !! How can I add an UDIO for an extended type? !! The following line causes compilation error generic :: write(unformatted) => write_unfmt_myint end type myint_t contains subroutine write_unfmt_mydata(dtv, unit, iostat, iomsg) class(mydata_t), intent(in) :: dtv integer, intent(in) :: unit integer, intent(out) :: iostat character(len=*), intent(inout) :: iomsg write(unit, iostat=iostat, iomsg=iomsg) dtv%name end subroutine write_unfmt_mydata subroutine write_unfmt_myint(dtv, unit, iostat, iomsg) class(myint_t), intent(in) :: dtv integer, intent(in) :: unit integer, intent(out) :: iostat character(len=*), intent(inout) :: iomsg write(unit, iostat=iostat, iomsg=iomsg) dtv%mydata_t write(unit, iostat=iostat, iomsg=iomsg) dtv%nn write(unit, iostat=iostat, iomsg=iomsg) dtv%xx(1:nn) end subroutine write_unfmt_myint end module mymod program test use mymod type(mydata_t) :: dd type(myint_t) :: ii dd = mydata_t( 'xyz' ) ii%name = 'abc' ii%nn = 100 allocate(ii%xx(ii%nn)) ii%xx = 5 open(10, file='test.dat', form='unformatted') write(10) dd write(10) ii end program test
FortranFan
"error #8638: The type/rank signature for arguments of this specific subroutine is identical to another specific subroutine that shares the same defined I/O." Anyone has idea how to do this? ..
With your design with the derived type and its extension type in the same module and thus any considerations of PRIVATE/PUBLIC attributes being moot, you need to effectively employ the "override" feature in standard Fortran to point the specific binding in the extension type to its own implementation.  The generic binding can be retained as-is.
      integer :: nn
   contains
      ! "override" write_unfmt_mydata with a specific procedure binding
      ! to myint_t
      procedure :: write_unfmt_mydata => write_unfmt_myint
   end type myint_t
Juergen_R_R
Valued Contributor II
Abstract interfaces?
FortranFan
      integer :: nn
   contains
      ! to myint_t
   end type myint_t
Dong_Zheng
@FortranFan,
Thanks. This works.
FortranFan
@Dong Zheng,
Please note if you wish to follow suggested good practices with object-oriented (OO) design that starts with "information hiding" but yet strive to have your Fortran derived types reflect and OO "class" in conjunction with Fortran standard facilities of having methods operate on a "class" and inherit and employ polymorphism in terms of Fortran type-bound procedures and their extension, then consider having each derived type in its own module, control information in terms of PRIVATE/PUBLIC attributes, adopt "names" of specific bindings via xx => yy option, etc. as shown below.  I don't extend the concept to data encapsulated by the derived type but the same principles apply.  Proceed carefully though because OO, like pointers, can give coders a long rope to tie themselves up in all kinds of knots if not handled carefully.
module mydata_m
   implicit none
   private
   type, public :: mydata_t
   contains
      private
      procedure, pass(dtv) :: write_unfmt => write_unfmt_mydata
      generic, public :: write(unformatted) => write_unfmt
   end type mydata_t
contains
end module mydata_m
module myint_m
   use mydata_m, only : mydata_t
   implicit none
   private
   type, extends(mydata_t), public :: myint_t
      integer :: nn
   contains
      private
      procedure, pass(dtv) :: write_unfmt => write_unfmt_myint
   end type myint_t
contains
      write(unit, iostat=iostat, iomsg=iomsg) dtv%xx(1:dtv%nn)
end module myint_m
program test
   use myint_m, only : myint_t
   implicit none
   type(myint_t) :: ii
   ii%name = 'abc'
   ii%nn = 100
   ii%xx = 5
   write(10) dd
   write(10) ii
end program test
Dong_Zheng
@FortranFan Thanks for the advice and I totally agree with you. However, when I test the code you posted above. It compiled with no problem but did not work as expected. I add a print statement in both "write_unfmt_mydata" and "write_unfmt_myint" respectively. It shows that "write_unfmt_myint" is not used. When I rearrange your code (with out change) in to one module, then it works fine. I cannot figure out why. Could you have a look? The test code is attached.
FortranFan
Dong Zheng wrote:
.. when I test the code you posted above. It compiled with no problem but did not work as expected. I add a print statement in both "write_unfmt_mydata" and "write_unfmt_myint" respectively. It shows that "write_unfmt_myint" is not used. ..
My hunch at present is this is a compiler bug in Intel Fortran.  Note the output with gfortran is as I currently expect - see below.  I'll check the standard further on this.
C:\Temp>type p.f90
module mydata_m
   implicit none
   private
   contains
      private
   end type mydata_t
contains
      print *, 'in mydata'
end module mydata_m
module myint_m
   implicit none
   private
      integer :: nn
   contains
      private
   end type myint_t
contains
      print *, 'in myint'
end module myint_m
program test
   use, intrinsic :: iso_fortran_env, only : compiler_version
   implicit none
   type(myint_t) :: ii
   print *, "Compiler Version: ", compiler_version()
   ii%name = 'abc'
   ii%nn = 100
   ii%xx = 5
   write(10) dd
   write(10) ii
end program test
C:\Temp>gfortran -Wall -std=f2018 p.f90 -o p.exe
C:\Temp>p.exe
 Compiler Version: GCC version 10.0.0 20190512 (experimental)
 in mydata
 in myint
 in mydata
C:\Temp>
