29642 Discussions
Using GDB to debug an MPI program in Fortran (on MAC)
Diego_S_
Hello, I am trying to debug an MPI fortran program using the advice from this post: (Using GDB to debug an MPI program in Fortran). The idea is to place an MPI_BARRIER inside a DO WHILE loop and then attach gdb to the right process with something like
gdb -pid 12345
However, I keep getting the following message:
warning: unhandled dyld version (15)
0x00007fffb6f2ef46 in ?? ()
 When I try:
(gdb) info locals
I get "No symbol table info available". As a result, I can not attach gdb to the running process. I am working with MacOS 10.12 (Sierra), gdb 8.0, and compiling with mpif90 configured for ifort (version: 17.0.4). Any ideas about what could be the cause for this problem?
