29400 讨论
Using Intel Visual Fortran 9.0 with VS 2005 from the command line
Steven_L_Intel1
1,580 次查看
Intel Visual Fortran 9.0 does not integrate with Visual Studio 2005. Support for VS2005 will come in a new version to be released in May.
For use from the command line only, version 9.0.030, available from Intel Premier Support File Downloads, will recognize VS2005 (including the Express Edition) for command line use. Note that even when we release our new version with VS2005 support, VS2005 Express Edition will not enable IDE integration as Microsoft has prevented third-party products from doing so.
Message Edited by Steve_Lionel on 04-27-2006 05:53 PM
0 项奖励
9 回复数
LexiS_Intel
主持人
1,580 次查看
Hi Steve,
What's the best way for users to request the beta?
Thanks - Lexi
0 项奖励
Steven_L_Intel1
1,580 次查看
Customers can send me mail at steve.lionel at intel.com. They should include their full contact information including company name and telephone number. We do not promise to accept all requests.
0 项奖励
Steven_L_Intel1
1,580 次查看
As of version w_fc_c_9.0.030, the compiler installation will automatically detect Visual Studio 2005, including Express Edition, and offer to install command-line integration for it. So, as of this version, you don't have to manually edit the installed files.
If you are an Express Edition user, we recommend that you also download and install the Microsoft Platform SDK before installing the compiler so that you have access to the Win32 API libraries which are not provided with VS2005 Express Edition.
Please note that Developer Studio integration into VS2005 is NOT supported in Intel Visual Fortran 9.0.
0 项奖励
AONym
新分销商 II
1,580 次查看
I understand that VF9.0 does not support integration into VS2005, and that VF9.1, due May 2006, will.
I would like to be absolutely clear on what VF9.1 will do. I have VS6 and CVF6.x, which work together in the IDE: building, linking and debugging pgms which have C, C++ and Fortran modules works smoothly. I never use the command line for anything.
Will VF9.1 integrate with VS2005 in the same way, without using the command line? Will I be able to use the VS debugger on Fortran modules directly? Are there any other gotchas I should know about?
0 项奖励
Steven_L_Intel1
1,580 次查看
It's pretty much the same, especially debugging. The one issue which was a change MS introduced in VS.NET 2002 is that your mixed C/Fortran project has to turn into two projects in a "solution". The project upgrade wizard handles that for you. For more details, see this migration article.
0 项奖励
thomas-howsman
初学者
1,580 次查看
Perhaps I'm doing something wrong, but when I try to install the w_fc_c_9.0.030_IA32.exe, I get part way through the installation and thenan error occurs that says:
"The contents of this file cannot be unpacked. The executable you are trying to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again."
Well, I downloaded again, and had the same problem. I even tried the installation on a different computer and same problem.
Has anyone else seen this problem?
Tom
0 项奖励
Steven_L_Intel1
1,580 次查看
Make sure that you left click on the link and let the browser prompt you to save the file. There's a problem if you right click and do Save As.
0 项奖励
alireza
初学者
1,580 次查看
I am trying to setup ifort9.0/VS2005 for my boss. However after reading this thread I realized why it is not working. Is the 9.1 version really due in May and does it integrate with VS2005? And if so, is it possible to receive a beta version and try it? I really need to do this as soon as possible and any help or advice will be highly appreciated.
Ali
0 项奖励
Steven_L_Intel1
1,580 次查看
9.1 will be out in early May and will fully support VS2005 (Standard Edition or higher). The beta is now closed - sorry.
0 项奖励
回复
