Using Static Library in Fortran Composer XE
Rohaldin_M_
I have tried to include a static library in Intel Fortran composer Xe2013. but I got lots of error. I have attached some pictures to show the procedure I did and also error file.
thnaks
Lorri_M_Intel
If you look on your property pages, under Fortran->Libraries, you will probably see that it specified debug C libraries.
Unclick that, and use the non-debug C libraries.
The error you are getting is because you are linking against both the debug and non-debug versions of the C libraries.
                  --Lorri
Rohaldin_M_
Many many thanks. I changed it to a Multithreaded runtime library and it works.
