I am using IFORT 18.0.3 on CentOS 7.4.
The code example (bottom, from https://github.com/open-mpi/ompi/issues/3409#issuecomment-296904409) compiles and runs well with gfortran7/open-mpi and pgi/open-mpi. (independent of the open-mpi version)
However, with ifort/open-mpi it gives a segmentation fault iff run on two or more cores. With ifort/intel-mpi the code does not even compile:
mpi_example_5_21.f90(31): error #7061: The characteristics of dummy argument 1 of the associated actual procedure differ from the characteristics of dummy argument 1 of the dummy procedure. [MY_USER_FUNCTION] call MPI_Op_create(user_fn=my_user_function, commute=.true., op=myOp) ------------------------------^ mpi_example_5_21.f90(31): error #7062: The characteristics of dummy argument 2 of the associated actual procedure differ from the characteristics of dummy argument 2 of the dummy procedure. [MY_USER_FUNCTION] call MPI_Op_create(user_fn=my_user_function, commute=.true., op=myOp) ------------------------------^
Thanks a lot for any help!
Code:
module foo
contains
subroutine my_user_function( invec, inoutvec, len, type )
use, intrinsic :: iso_c_binding, only : c_ptr, c_f_pointer
use mpi_f08
type(c_ptr), value :: invec, inoutvec
integer :: len
type(MPI_Datatype) :: type
real, pointer :: invec_r(:), inoutvec_r(:)
if (type%MPI_VAL == MPI_REAL%MPI_VAL) then
call c_f_pointer(invec, invec_r, (/ len /) )
call c_f_pointer(inoutvec, inoutvec_r, (/ len /) )
inoutvec_r = invec_r + inoutvec_r
end if
end subroutine
end module
program mpi_example_5_21
use mpi_f08
use foo, only: my_user_function
implicit none
type(MPI_Op) :: myOp
integer :: rank, nproc
real :: R(100), S(100) = 1.0
call MPI_Init
call MPI_Comm_rank(comm=MPI_COMM_WORLD, rank=rank)
call MPI_Comm_size(comm=MPI_COMM_WORLD, size=nproc)
call MPI_Reduce(sendbuf=S, recvbuf=R, count=size(S), datatype=MPI_REAL, op=myOp, root=0, comm=MPI_COMM_WORLD)
call MPI_Finalize
if (rank == 0) write (*,*) merge('PASS', 'FAIL', all(R == S(1)*nproc))
end program mpi_example_5_21
In case this is the wrong place to ask the above question, could you tell me a better one?
Thank you very much!
My install of the latest Intel MPI doesn't include an mpi_f08 module (puzzling), but it doesn't include sources for mpi.mod either. You would need to compare the declaration of the procedure arguments of MPI_op_create in your version of that module (assuming you have the source) with your actual routines. Looking at mpi-forum.org documentation for MPI_op_create, I see that the INVEC and INOUTVEC arguments are described as arrays of some type, whereas in your code they are TYPE(C_PTR). Maybe mpi_f08 defines them that way, I don't know. I do note that you give those arguments the VALUE attribute but don't give the procedure the BIND(C) specification. In this case, VALUE doesn't do what you evidently think it does - it says that an anonymous copy of the argument is passed by reference. I could well believe that this error leads to issues with the other MPI implementations.
