Using variables in a structure repeatedly - as in Pascal "WITH"
Adrian_F_1
If I have a structure called fred which contains many variables, eg. x and y, is there a way to avoid keeping having to preface the variables everywhere I use them with "fred%".  This used to be available in Pascal as:
with fred
  begin
  x = 555
  y = 666
  end
Long shot...
Steven_L_Intel1
The equivalent feature in Fortran is ASSOCIATE.
Adrian_F_1
Not sure how that is supposed to work with the fred example above.  I'd like to strip away the parent structure name.
FortranFan
You can look in Modern Fortran Explained by Metcalf et al. for more details, but here is a simple example:
program p
   type :: t
      integer :: x
      integer :: y
   end type t
   type(t) :: foo
   foo%x = 1
   foo%y = 2
   asc: associate ( x => foo%x, y => foo%y )
      print *, " foo%x = ", x
      print *, " foo%y = ", y
   end associate asc
   stop
end program p
mecej4
The ASSOCIATE construct is similar to, but not quite the same as Pascal's WITH.
Here is what you can do in the example case that you wrote about. Note that ASSOCIATE has more features than WITH. In the example below, you may see that there are multiple associations set up, but note that the individual associations do not always have to be components of a single user defined type.
program xassoc
type st
   integer x
   integer y
end type
type(st) fred
fred=st(15,36)
associate(x=>fred%x, y=>fred%y)
   write(*,*)x,y,x+y
end associate
end program
Adrian_F_1
ok thanks.  Two questions.
1. I see you have not declared the x and y referred to on the left hand side of the associate statements.  Does the compiler just assume they are the same type as those on the right?
2. So if fred is large, then I have to have a very long associate statement at the beginning of the file.  I guess this can be hidden in an include file.
mecej4
Section 8.1.3.2 of the F2008 standard says, "The associating entity assumes the declared type and type parameters of the selector.".
At the beginning of the file? Possible, but not a good idea. I'd suggest making ASSOCIATE constructs short, because the body of the construct is seemingly easy to read, but its meaning is not knowable without knowing the associations. I think of ASSOCIATE as a limited and short-in-scope variable renaming facility.
Hiding the ASSOCIATE in an include file would make things even worse for the reader.
I tried out the example code in #5 in the VS2013 debugger, and I see some rough edges there. In the local panes I see X and Y shown twice, as if they were separate variables. (This is probably the result of an error in debug symbols generation, as described in https://software.intel.com/en-us/forums/topic/540783, and should be fixed when IFort 16.0 comes out). You have to look at the source code pane to become aware of the association. Before the construct is entered, these alias names are shown with "undefined" values. However, as of now, when execution has halted on a line within the construct, we see three copies of X and Y.
Steven_L_Intel1
I'd also comment that hiding information on a large scale can make maintenance more difficult. Where ASSOCIATE can really help is if you have a nested structure, such as a%b%c where c is also a derived type. You can use ASSOCIATE to create an associate name for a%b%c (call it xc) and then reference xc%whatever. This also works for array references.
Adrian_F_1
Yes I remember all too well the pitfalls of WITH in Pascal.  Just that the separator '%' in Fortran just makes the code that much more unreadable than the unobtrusive '.'  So much so that I'd prefer to hide it.
Adrian_F_1
Not sure what is wrong here:
      program main
      type :: t_net
        integer, pointer:: nodes(:)
      end type t_net
      type(t_net) :: net
      associate(nodes => net%nodes)
      allocate(nodes(nnode))
      end associate
      end
ifort aa.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 14.0.2.176 Build 20140130
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
aa.f90(11): error #8306: Associate name defined in ASSOCIATE or SELECT TYPE statements doesn't have ALLOCATABLE or POINTER attribute   [NODES]
compilation aborted for aa.f90 (code 1)
IanH
As the message says, the associated name is never a pointer or allocatable, even if you are associating it with something that appears to be an allocatable or pointer.  It is associated with the data object designated by the right hand side of the =>, rather than the things that holds the data object.  Perhaps the reasoning is a bit obscure, but this approach is consistent with other aspects of the design of the language - conceptually the allocation status of net%nodes in your example is part of the value of the parent net object, not the net%nodes component itself.
On a different tack, if you are defining a particular structure from scratch, then structure constructors may be helpful.
type t
  integer :: x
  integer :: y
end type t
type(t) :: fred
fred = t(x=555, y=666)
If, instead you are updating part of an existing object I would be tempted to write a function that used optional arguments to assist with the update:
type t
  integer :: x
  integer :: y
end type t
interface t
  procedure :: t_update
end interface t
function t_update(original, x, y) result(updated)
  type(t), intent(in) :: original
  integer, intent(in), optional :: x
  integer, intent(in), optional :: y
  type(t) :: updated
  updated = original
  if (present(x)) updated%x = x
  if (present(y)) updated%y = y
end function t_update
type(t) :: fred
fred = t(555,666)
fred = t(fred, Y=777)
Adrian_F_1
mecej4 wrote:
Ok so from IanH's reply to my blind adherence to the above standard, you can use allocatables or pointer variable types, you just can't allocate them.  This works:
      program main
      implicit none
      type :: t_net
      end type t_net
      type(t_net) :: net
      allocate(net%nodes(1))
      call sub(net)
      write(*,*) net%nodes(1)
      end
      subroutine sub(net)
      implicit none
      type :: t_net
      end type t_net
      type(t_net) :: net
      nodes(1) = 12345
      end associate
      return
      end
IanH
Adrian F. wrote:
Ok so from IanH's reply to my blind adherence to the above standard, you can't use allocatables or pointer variable types.
You can't do things relating to the allocation status of selectors with the allocatable attribute or the pointer association status of selectors with the pointer attribute, but you can still reference them and define them through the associate name (if the selector is defined/definable).  If the selector has the target attribute (which is the case for anything that a associated pointer is pointing at) then the associate name also has the target attribute, so you can associate pointers with the associate name.
Adrian_F_1
ianh wrote:
ok you can use them just not allocate them.
jimdempseyatthecove
And remember to be careful not to deallocate or reallocate an allocatable/pointer that has an active associated selector. (somewhat like using a C pointer where other code modified the memory state such that the pointer is no longer valid (though the memory may be a valid address).
This is another reason for making your associate blocks small enough to assure you do not make this faux pas.
Jim Dempsey
Adrian_F_1
I hope the associate is not transferred into called subroutines.  ie is more like an include statement and limited to the file it is in.  If so, it is easy to manage.
IanH
The associate name is only usable in the lexical scope of the associate construct (in the source that physically appears between the ASSOCIATE and END ASSOCIATE statements..  You can pass the object nominated by the associate name to other procedures though, but the characteristics of the actual argument are the characteristics of the associate name.
type :: t
  integer, allocatable :: z
end type t
t%z = 3
associate (chicken => t%z)
  ! t%z is allocatable, but chickens never are.
  call proc(chicken)
end associate
subroutine proc(arg)
  integer, intent(in) :: arg
  print *, arg   ! will print 3.
end subroutine proc
Adrian_F_1
