VS Integration in XE 2017 update 4 broken source window
Andrew_Smith
Valued Contributor I
When I open a source file it shows all blank, only the tab at the top tells me it is open.
Microsoft Visual Studio Professional 2015
Version 14.0.25431.01 Update 3
Microsoft .NET Framework
Version 4.7.02046
Installed Version: Professional
Visual Basic 2015   00322-40000-00000-AA974
Microsoft Visual Basic 2015
Visual C# 2015   00322-40000-00000-AA974
Microsoft Visual C# 2015
Visual C++ 2015   00322-40000-00000-AA974
Microsoft Visual C++ 2015
Visual F# 2015   00322-40000-00000-AA974
Microsoft Visual F# 2015
Application Insights Tools for Visual Studio Package   7.0.20622.1
ASP.NET and Web Tools 2015 (RC1 Update 1)   14.1.20203.0
ASP.NET Web Frameworks and Tools 2012.2   4.1.41102.0
For additional information, visit http://go.microsoft.com/fwlink/?LinkID=309563
ASP.NET Web Frameworks and Tools 2013   5.2.40314.0
For additional information, visit http://www.asp.net/
Azure App Service Tools v2.7.1   14.0.11112.0
Common Azure Tools   1.8
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
GitHub.VisualStudio   1.0
A Visual Studio Extension that brings the GitHub Flow into Visual Studio.
Intel Debugger for Heterogeneous Compute   1.0
Provides debugging capabilities for compute shaders running on the Intel GPU.
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for C++ Windows*   Package ID: w_comp_lib_2017.4.210
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2015, Version 17.0.76.14, Copyright © 2002-2017 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows*   Package ID: w_comp_lib_2017.4.210
Intel® Parallel Studio XE 2017 Update 4 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 17.0.0047.14, Copyright © 2002-2017 Intel Corporation. All rights reserved.
JavaScript Language Service   2.0
JavaScript Project System   2.0
Microsoft Azure Mobile Services Tools   1.4
Microsoft MI-Based Debugger   1.0
Provides support for connecting Visual Studio to MI compatible debuggers
NuGet Package Manager   3.4.4
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
PreEmptive Analytics Visualizer   1.2
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
Python Tools for Visual Studio   2.2.50113.00
Python Tools for Visual Studio provides IntelliSense, projects, templates, Interactive windows, and other support for Python developers.
Python Tools for Visual Studio - Django Integration   2.2.50113.00
Provides templates and integration for the Django web framework.
Python Tools for Visual Studio - Profiling Support   2.2.50113.00
Profiling support for Python projects.
SQL Server Data Tools   14.0.60519.0
Microsoft SQL Server Data Tools
TypeScript   1.8.36.0
TypeScript tools for Visual Studio
Kevin_D_Intel
Others experienced this in the past with VS2015. The advice in [How to fix] MS VS2015 text editor is blank after upgrading Intel® parallel Studio XE I believe will help.
Kevin_D_Intel
Andrew_Smith
Thanks. Working like new
Johannes_Rieke
New Contributor III
Hi all, I had the same problem and could fix it like for PSXE17 update 2 (https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/713771).
@Kevin Besides it's claimed the root cause is a corrupted cache in VS, the problem was not present in PSXE2016 with all updates and PSXE2017 initial and update 1 (VS2015 various updates). It's unclear, whether the Intel VS-integration corrupts the cache?
This problem normally caused by corrupted VS cache. This usually happens when installing or updating extensions or other Visual Studio components.
I did not installed any other update meanwhile. Isn't there a way, that the installer can check this? Before updating everything was fine. Please, improve the installer.
Kevin_D_Intel
It happens where our product is not involved also. (See here). However, your same questions/ideas have been asked of and are being investigated be our IDE integration and installation developers to see whether it can be avoided.
garylscott1
My experience with update 2 (causing the above editor problem) has me trepidatious about installing update 4...will somebody please hold my hand???
