Valid arguments for trig functions
tmcole
Can anyone tell me where I can find out the range of valid numbers for trig functions? I am having problems with SINH computations.
Intel_C_Intel
Couldn't find anything about this myself either.
Just running through a loop in CVF 6.6b, with 4 byte reals it starts producing infinity as a result with inputs 89 and 90, and craps out totally with an error between 710 and 711. If you switch the default reals to 8 bytes, it will keep working after 89, but still
craps out between 710 and 711. I didn't try. For negative arguments, it produces -infinity between -89 and
-90, and craps out between -710 and -711. With 8 byte
reals as default, it works after -90, but still craps out
between -710 and -711. Here's the program. I'm running it in debug configuration. The error it gives is
overflow.
do 100 i=64,1024
x = -i
y = sinh(x)
write(*,*) x,y
100 continue
read(*,*) i
stop
end
gfthomas8
If you want sinh(x) then you must have
abs(x)
otherwise it'll overflow.
HTH,
Gerry T.
TimP
Careers have been made out of this topic; there is no single simple answer. The ELEFUNT test suite (look up on Google) checks the numerical behavior of an implementation, including picky tests for failures at boundary values.
A "naive" or sloppy version of sinh() would "fail" (e.g. produce Infinity) for the same arguments where exp() would fail, while a correct implementation will not go Infinity until .5*exp(x) must be represented as Infinity. It may not be practical to get the point where it goes Infinity exactly right.
Also, a sloppy version may be inaccurate for small values of x, or even fail. Supposing that x is such that exp(x)==1. Then, if you calculate .5*(exp(x)-exp(-x)), you get 0 when you want x. A correct version will take care of this, by using a different method for x near 0, and matching that expansion correctly to the one for large x, or by basing the calculation on an accurate representation of .5*(exp(x)-1).
There are no invalid arguments, other than NaN, but there are arguments which will produce a result which will likely break your program.
Even when using the x87 built-in intrinsics, it takes about 16 lines of C/asm source to get sinh() right. Certain compilers which expand code in line, using the x87 intrinsics, will skip one or more of the nit-picky precautions, in the expectation that people don't insist on ability to pass all the ELEFUNT tests, or would prefer speed or small generated code size.
gfthomas8
If you want the sinh(x) then you must have
abs(x)
HTH,
Gerry T.
gfthomas8
Sorry for the confusion, huge should read 2*huge, I think,:-).
Ciao,
Gerry T.
