Variable number of nested loops
roy437
How to write a Fortran code with a variable number of nested loops.
Thank you.
Isaac_E_Lagaris
NESTED  DO loops
Suppose we have the following simple program:
      program test
      parameter (m=4)
      dimension ib(m),ie(m),is(m),i(m)
      data ib/1,1,1,1/
      data ie/3,4,-3,2/
      data is/1,2,-2,1/
      write(*,*) 'Enter a number >=1,and <=',m
      read(*,*)n
      if (n.gt.m) stop
      if (n.lt.1) stop
      call  donest(ib,ie,is,n,i)
      end
 We want to construct:  subroutine donest(ib,ie,is,n,i)  such as to implement a variable number of NESTED DO-loops.
 For example for  n=2  we should get the output that the following code yields:
EQUIVELANT CODE:
      DO 1 I1=IB(1),IE(1),IS(1)
        DO 2 I2=IB(2),IE(2),IS(2)
           WRITE(*,*)I1,I2
 2      CONTINUE
 1    CONTINUE
 OUTPUT:
1 1
1 3
2 1
2 3
3 1
3 3
Similarly for  n=3  we have:
 EQUIVELANT CODE:
          DO 3 I3=IB(3),IE(3),IS(3)
             WRITE(*,*)I1,I2,I3
 3        CONTINUE
 2      CONTINUE
 1    CONTINUE
 OUTPUT:
1 1  1
1 1 -1
1 1 -3
1 3  1
1 3 -1
1 3 -3
2 1  1
2 1 -1
2 1 -3
3 1 -3
Correspondigly for n=4, etc
Sample Solution
      dimension ib(n),ie(n),is(n),i(n)
* Determine if the loops are doable and the exact right bounds
      do 2 j=1,n
        if (is(j).eq.0) return
        k = (ie(j)-ib(j))/is(j)
        if ( ib(j).le.ie(j) .and. is(j).gt.0 ) then
          ie(j)=ib(j)+ k*is(j)
        elseif   ( ib(j).ge.ie(j) .and. is(j).lt.0 ) then
        else
          return
        endif
 2    continue
* Set initial values
      do 3 j = 1,n
        i(j) = ib(j)
 3    continue
* Print all values now (running the innermost loop
 4    continue
      do 1 in = ib(n),ie(n),is(n)
         i(n) = in
         write(*,*)(i(j),j=1,n)
 1    continue
      do 10 j = n-1,1,-1
        if ( i(j).ne.ie(j) ) then
          i(j) = i(j)+is(j)
          go to 4
        else
          i(j) = ib(j)
        endif
 10   continue
      end
      program test
      parameter (m=4)
      data ib/1,1,1,1/
      data ie/3,4,-3,2/
      data is/1,2,-2,1/
      read(*,*)n
      if (n.gt.m) stop
      if (n.lt.1) stop
      end
Steve_Lionel
Please start a new thread, rather than reopening one more than three years old.
jimdempseyatthecove
I agree, start a new thread.
By the way, is this a problem for a computer science course?
If so, I suggest you think about a solution that involves recursion.
Jim Dempsey
