29293 Discussions
Visual Studio compiler integration
wkramer
I have installed Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* .NET 2003, 11.0.3453.2003.
However, I don't see any of the new and changed Visual Studio* integration features mentioned in the release notes for version 11.0.072.
I know that support for Microsoft Visual Studio .NET 2003 will be removed in a future release of the product, but I
expected that itto function for version 11.
My operating system is MS Windows XP home, SP 3
And the developer environment is:
Microsoft Visual C++ .NET 69459-005-7473167-18548
Microsoft Visual Studio .NET 2003 Service Pack 1 (KB918007)
Is there a solution for this issue?
Walter Kramer
wkramer
I used the repair feature of setup.exe, and now the features are available.
Except "In Help > About, information on the installed Intel Fortran Compiler package identification (version) is provided"
But I don't care about that.
Walter Kramer
Steven_L_Intel1
Try running the attached program.
wkramer
Hello Steve,
I ran the the program, but I still don't see the compiler version information in help/about.
I do encounter another more serious problem after upgrading from version 10 to 11, involving unresolved external symbols in a program thatran without a problem in the past. So I think I will first completely removeIDE and compiler and try to reinstall everything to see if that helps.
Walter Kramer
Steven_L_Intel1
Ok. If you still have problems after that, let us know and be sure to provide details on the problem. (Attaching a build log from the Debug or Release folder is best.)
wkramer
Reinstallation solved the problem with building the program. Compiler package information can be found under Tools>Options>Intel Visual Fortran>Compilers, not under Help>About.
Walter Kramer
Steven_L_Intel1
Quoting - wkramer
That's not quite true. The version of the compiler you installed is under Help > About. What's in the Tools menu is a way to select among the different versions of the Intel compiler that you may have installed.
