Visual Studio compiler integration
wkramer
I have installed Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* .NET 2003, 11.0.3453.2003.
However, I don't see any of the new and changed Visual Studio* integration features mentioned in the release notes for version 11.0.072.
I know that support for Microsoft Visual Studio .NET 2003 will be removed in a future release of the product, but I
expected that itto function for version 11.
My operating system is MS Windows XP home, SP 3
And the developer environment is:
Microsoft Visual C++ .NET 69459-005-7473167-18548
Microsoft Visual Studio .NET 2003 Service Pack 1 (KB918007)
Is there a solution for this issue?
Walter Kramer
wkramer
I used the repair feature of setup.exe, and now the features are available.
Except "In Help > About, information on the installed Intel Fortran Compiler package identification (version) is provided"
But I don't care about that.
Walter Kramer
Try running the attached program.
wkramer
Hello Steve,
I ran the the program, but I still don't see the compiler version information in help/about.
I do encounter another more serious problem after upgrading from version 10 to 11, involving unresolved external symbols in a program thatran without a problem in the past. So I think I will first completely removeIDE and compiler and try to reinstall everything to see if that helps.
Walter Kramer
Ok. If you still have problems after that, let us know and be sure to provide details on the problem. (Attaching a build log from the Debug or Release folder is best.)
wkramer
Reinstallation solved the problem with building the program. Compiler package information can be found under Tools>Options>Intel Visual Fortran>Compilers, not under Help>About.
Walter Kramer
Quoting - wkramer
That's not quite true. The version of the compiler you installed is under Help > About. What's in the Tools menu is a way to select among the different versions of the Intel compiler that you may have installed.
