Visul Studio Integration Problem
HKort
I noticed that I have a bunch of IVF Fortran compiler versions listed in my Visual Studio options that are no longer installed on my system after installtion of updates. Is there a way to delete these from the list of compiler version in the options menu?
Haje
Steven_L_Intel1
Start > Run. Type REGEDIT, click OK
Click on + symbol next to the following names, in order:
  • HKEY_LOCAL_MACHINE
  • Software
  • Intel
  • Compilers
  • FORTRAN
You will see one or more registry keys named after versions, such as 100.025. For each one you want to delete, click on the name and press the delete key.
Steven_L_Intel1
Oh, be aware that if you install an update to 10.0, it does NOT install any previous updates. You must remove those separately if desired.
HKort
Steve,
thanks the registry edits did the trick!
Haje
Steven_L_Intel1
Good. Starting with version 10, uninstalling an old version is supposed to remove the entry for that version.
