29261 Discussions
Wanted: Reliable Integer -> Real -> Integer conversion
anthonyrichards
New Contributor III
I am converting some Mathcad code to Fortranroutinesand need a reliable method of storing Integers as reals and then converting them back to Integer for use as array subscripts, without having rounding problems with the reals. Suggestions would be appreciated.
TimP
I can't read between your lines, so I may be missing your point. A real data type can hold integers exactly, up to intval <= 1/EPSILON(realval). If you can use selected_int_kind and selected_real_kind, you can choose data types, within limits, such that all the integers fit in the real data type.
For your real to integer conversions, you may want
intval = nint(realval,kind(intval))
anthonyrichards
New Contributor III
