29239 Discussions
Warning (528): IEEE_Underflow is signaling
MrRocketman
Débutant
1 343 Visites
How can I prevent the pop up message window "Warning (528): IEEE_Underflow is signaling"? I am using IVF 14.0.3, IMSL 7.0.1, compiler settings fpe:0, and using the MKL libs option. The main program USES imsl_v7 which is just
module imsl_v7
include 'link_fnl_static.h'
end module imsl_v7
The program runs fine but I get the message at the end which I don't want.
0 Compliments
3 Réponses
Steven_L_Intel1
Employé
1 343 Visites
Are you compiling with /standard-semantics ("Enable Fortran 2003 semantics")? If so, you'll get this message. To turn it off, add:
/assume:nofpe_summary
under Fortran > Command Line > Additional Options
0 Compliments
MrRocketman
Débutant
1 343 Visites
That worked.
Thanks Steve L.
0 Compliments
Steven_L_Intel1
Employé
1 343 Visites
Great. By the way, please go to your Dashboard (click on your user ID in the upper right corner and select Dashboard), then go to Profile and select a "Display Name" that isn't your email address. This will prevent your email address from showing here in the forum.
0 Compliments
Répondre
