29413 Discussions
Warning (528): IEEE_Underflow is signaling
MrRocketman
How can I prevent the pop up message window "Warning (528): IEEE_Underflow is signaling"? I am using IVF 14.0.3, IMSL 7.0.1, compiler settings fpe:0, and using the MKL libs option. The main program USES imsl_v7 which is just
module imsl_v7
include 'link_fnl_static.h'
end module imsl_v7
The program runs fine but I get the message at the end which I don't want.
Are you compiling with /standard-semantics ("Enable Fortran 2003 semantics")? If so, you'll get this message. To turn it off, add:
/assume:nofpe_summary
under Fortran > Command Line > Additional Options
MrRocketman
That worked.
Thanks Steve L.
Great. By the way, please go to your Dashboard (click on your user ID in the upper right corner and select Dashboard), then go to Profile and select a "Display Name" that isn't your email address. This will prevent your email address from showing here in the forum.
