What does this run-time check failure mean?
dondilworth
New Contributor II
My program runs fine, but in debug  mode I get this message:
Does anyone know what kind of errors will cause this message?  Variable THISNAME is a *40 character variable.
Steven_L_Intel1
With /check:stack enabled, code is added to check for inappropriate writes to stack outside of declared variables. Some part of your program is writing to memory where it shouldn't. Unfortunately, the error check may be considerably later than the code that did the corruption.
dondilworth
New Contributor II
Right.  Found it.  Many thanks!
