What is -2.0**2
Nick3
I'm looking at some code that for repro-sakes I can reduce to this:
program main
real rslt
rslt = -2.0**2
print *,rslt
end
The actual equation is 1.E0-6.E0/(PI**2)*EXP(-PI**2*TAU2/A0**2) but I think the above example will suffice for my question.
Why is rslt -4.0 ?  How does the compiler determine that I want
2.0
squared
negate
Rather than
-2.0
squared
The minus sign just confuses me here ... can somebody point me to a Fortran standard for how this is evaluated, or is this a compiler standard?
Steve_Lionel
That page is simply wrong. Here is what the standard says - note the example that is exactly your case.
Ulrich_M_
google "operator precedence fortran" and you will see that exponentiation is executed before the negation in the absence of parentheses...
Nick3
The very first hit
https://www.tutorialspoint.com/fortran/fortran_operators_precedence.htm
Says "Logical NOT and negative sign" takes precedence before Exponentiation, and this contradicts what I'm seeing.
Steve_Lionel
Steve_Lionel
I should also point out that Fortran differs from some other languages in how it treats things such as -2.0.  This is not a negative 2.0 as a single entity, it's 2.0 with a unary negation applied to it. This trips up programmers coming from other languages.
n_scott_pearson
LOL! And even programmers who started in Fortran and then 'went to the dark side for a time'. Ok, I just realized it's been 45 years - and it was Fortran II - do I get a pass for that?           ;^)
JohnNichols
Valued Contributor III
No passes -- sorry you should know order of operation - this is why LISP is so much better
although some say Lost in Stupid Paratheses'
Arjen_Markus
Interestingly enough, if I were to see the expression "-2.0**2" (or the like) in a mathematical context, I would interpret it as "-(2.0**2)". In maths notation is everything, including precedence.
mecej4
I have sometimes wondered why the creators of Fortran chose to deviate from mathematical conventions in what the expression a/bc means, for real variables. In algebra, it means 'a' divided by the product of 'b' and 'c'. In Fortran, a/b*c is the same as ac/b, assuming no overflow, etc.
Steve_Lionel
That's simple - and most other languages I know are the same. "bc" could be a distinct variable. Keep in mind that blanks are ignored in fixed-form source.
I recall from my college days that the compiler we used, PL/C (a PL/I variant) tried to "fix" syntax errors, including replacing "b c" with "b*c".  In order to recognize "bc" as a multiplication, the compiler would have to know that all variables are single letters and that b and c were previously defined. Fortran, with implicit declarations, couldn't do that.
mecej4
Of course, an accommodation had to be made for variable names longer than one character, and it was necessary to show the multiplication operator explicitly.
What I wanted to say was that, to be consistent with the conventions of algebra that have existed for a few centuries, in Fortran, too, a/b*c should have stood for a/(b*c), not (a/b)*c.
A few years ago, I had stated the same question in a forum (possibly here), and Walt Brainerd had replied that he was in agreement.
JohnNichols
However, anecdotal evidence suggests that reverse Polish notation is more difficult for users to learn than algebraic notation
A note from Wikipedia -- but I still think the HP RPN is the best way to do math - fewer errors and in engineering errors are critical
( + (+ 3 4) 6) in LISP is completely clear
In moment of inertia calculation you get the A*y*y  - if you use an excel chart or Fortran you get some negative y's, so it makes it interesting to teach -- I had to explain that the -y is the number squared not negative y squared.
n_scott_pearson
This all leads into the topic of defensive programming. After having a number of 'trips' going from language to language - and especially to C++ - I got in the practice of explicitly including the brackets (or braces, whichever you prefer to call them). Some of the folks I worked with used to complain about me doing this. Too bad; better safe than sorry.
AlHill
More than defensive programming, it is actually part of documentation of the source, stating clearly what the programmer intended.   Always a good practice.
Doc
JohnNichols
1. LISP is never ambiguous
2. Fortran is interesting
3. C++ is for nerds
4. Python is for _________________
5. Forth is for real nerds
6. Basic is fum
JohnNichols
The Basica random number generator is still more random than any Intel Fortran Random number generator --
