During running a FORTRAN code, following error message occurs.
Debugging information for ERAUL201305.exe cannot be found or does not match. Binary was not built with debug information.
Do you want to continue debugging?
Yes No
If I choose Yes then following error message appears
Unhandled exception at 0x0044511f in ERAUL201305.exe: 0xC0000005:
Access violation writing location 0x00000000.
How can I solve this issue.
I am a novice so please reply in basic and easy to understand way.
PS) I am not sure if I have defined the project/solution and code source correctly.
Thanks in advance
Khoshravan
連結已複製
Dear Sergey
I changed what you mentioned and debugged the code.
It gives following error:
error PRJ0019: A tool retunred an error code.
But it doesn't give any futher info on the error.
How can I find the error?
