What to do when DEALLOCATE doesn't do its job?
FortranFan
Other than a plain, old bug, can anyone think of situations where DEALLOCATE statement will not deallocate the provided object, but yet it won’t return an error code and an error message?
We’ve a major problem with one of the use cases for an important code library where DEALLOCATE statement runs into such a problem.  The pseudo code is as follows:
    INTEGER :: Istat
    CHARACTER(LEN=80) :: ErrAlloc
    IF (ALLOCATED(Foo)) THEN
       DEALLOCATE(Foo, STAT=Istat, ERRMSG=ErrAlloc)  ! <= returns Istat of 0
       IF (Istat /= 0) THEN
          ... ! error handling
          RETURN
       END IF
    END IF
    ALLOCATE(Foo, STAT=Istat, ERRMSG=ErrAlloc) ! <-- failure, Istat=151; Foo already allocated.
       RETURN
    END IF
where Foo is an instance of an extensible derived type containing allocatable components as well as type-bound procedures.
The issue is the ALLOCATE statement fails with an error code of 151 and returns an error message, “an allocatable array is already allocated.” because the DEALLOCATE in the code block just prior to this hasn't done its its job but hasn't returned an error.   Note the IF (ALLOCATED(..)) check does indeed return true.
Isn't DEALLOCATE statement always supposed to return a non-zero error code if it is unable to deallocate the object for any reason?
The application structure is as follows: a Fortran main program calls DLL A which calls DLL B.  The main program has a “TYPE(Foo_t), ALLOCATABLE :: Foo” kind of declaration.  Foo is an argument specified with “TYPE (Foo_t), INTENT(INOUT) :: ” in some of the procedures in DLLs A and B which, under certain circumstances, will need to deallocate and reallocate Foo.  The code is built with /standard-semantics compiler option.
Any thoughts on what to check before I start thinking of this as a bug?
Andrew_Smith
Valued Contributor I
"Foo is an argument specified with “TYPE (Foo_t), INTENT(INOUT) :: ” in some of the procedures in DLLs A and B which, under certain circumstances, will need to deallocate and reallocate Foo"
It is not possible to deallocate something that was not declared allocatable or pointer. It should have given a compile error so yes its a bug.
Steven_L_Intel1
Without seeing a complete test case, it's hard to speculate, but we did have a bug where an INTENT(OUT) allocatable variable of derived type with an allocatable component didn't deallocate the component. This is fixed in the upcoming 15.0. But your problem seems different - I'll look forward to the complete test case.
FortranFan
Andrew,
Thanks, I think your conclusion that this is a bug does appear to be correct.  However some clarification may still be in order based on your comment, "It is not possible to deallocate something that was not declared allocatable or pointer."  Please note:
  • Foo is indeed declared as ALLOCATABLE type in the main program, as explained in the sentence previous to the one you quoted from my original post,
  • Foo is passed as an argument to procedures in DLLs A and B with an "INTENT(INOUT)" attribute, not INTENT(OUT) or INTENT(IN),
  • Within the DLL procedures, IF (ALLOCATED(Foo)) check works as expected,
  • The problem is with the DEALLOCATE(Foo, STAT=Istat, ERRMSG=ErrAlloc) statement within IF (ALLOCATED(Foo)) THEN.. block.  Foo doesn't get deallocated, yet Istat remains zero, and ErrAlloc is blank.
  • So a subsequent ALLOCATE(Foo, STAT=Istat, ERRMSG=ErrAlloc) statement fails with an Istat of 151 and ErrAlloc message of "an allocatable array is already allocated".  The program then shuts down due to this non-zero Istat value, albeit gracefully because the code does indeed have appropriate error handling scheme!
FortranFan
Steve,
Yes, I agree with you that the complete test case would be necessary to truly diagnose the problem because, after all, DEALLOCATE statement gets used all the time, and only a gazillion times in the various libraries I support, let alone every where else.
But as you can surmise, the situation becomes quite complicated when it comes to packaging the full program and shipping it over (corporate policy, auxiliary software and their licensing, etc.).
So I'm trying to create a small enough reproducer but it is proving nearly impossible (all simple cases work as expected, not a surprise right!?), hence I think this has something to do with memory requirements of the actual use case.
But I anticipated the difficulty in getting to the root of this matter and that's why I initiated this forum topic to see if anyone has any advice on what all I can check.  Anyways, I'll continue with the effort to create a reproducer.
In the mean time, please note:
  • the problem exists with both compiler 13 as well as compiler 2015 Beta (June update) versions,
  • the argument list declaration in my case is INTENT(INOUT), not INTENT(OUT).
Steven_L_Intel1
Please show the declaration of Foo and of its derived type, if any.
Andrew_Smith
The dummy argument declaration must have ALLOCATABLE specified:
TYPE (Foo_t), ALLOCATABLE, INTENT(INOUT) :: Foo.
It is illegal to try to dellaocate Foo within the subroutines without this.
Steven_L_Intel1
The compiler would give an error if FOO didn't have ALLOCATABLE or POINTER in the subroutine.
FortranFan
Thanks.  And very sorry for any added confusion, but the actual case is "TYPE(Foo_t), INTENT(INOUT) :: Foo" and it is DEALLOCATE(Foo%Bar, STAT..), not DEALLOCATE(Foo, STAT=..).  Note Bar is an allocatable component of Foo.  By the way, all interfaces and type definitions are explicit since everything is in modules, the modules are indeed available to callers, and everything is accessed via USE statements.
However, I think Andrew's comment in Quote #7 and Steve's request in Quote #6 have given me the clue I was looking for.  And that is, the problem most likely has to do with the BIND(C) attribute in the DLL procedures.  And that this code may most likely be non-conforming with C interoperability aspects of the Fortran standard.
However, none of this may let the compiler off the hook since it gives no errors or warnings, even though all the relevant flags have been turned on (/stand:f08, /warn:.. etc.).  Plus DEALLOCATE behaves oddly during execution which it shouldn't.  But I now think I can resolve this issue and also be able to create a reproducer for Intel team.
So many things to do, such little time!   Thank you much.
As goes the 37th item on " AFI's 100 Years... 100 Movie Quotes", "I'll be back"!
Steven_L_Intel1
Unless you used a syntax extension it's not likely you'd get a compiler error. It could be that you have a mismatch that results in data corruption.
jimdempseyatthecove
Therefor on its path from the main program through the call stack into the DLL, the attribute ALLOCATABLE was lost. If your above description is correct, then what it appears you are trying to do is to "cast" the ALLOCATABLE attribute to an argument that was once described without ALLOCATABLE. This isn't in compliance.
Your example doesn't show test of component of type, then deallocate, allocate of that component. It shows the allocated, dealocate, allocate of the object itself.
Note, Fortran may use a reference to the original object, or it may construct a descriptor of the original object (e.g. slice) and pass that.
When the original object reference is passed, and it is allocatable, then it is likely your test and use above will work provided everything was compiled with the same version of Fortran.
However, should a new descriptor be created, as in passing a portion of an array (with or without stride), or potentially when when one call level receives a reference of a descriptor, and passes it to a next level without a descriptor (iow pointer to POD), then you attempt redefine the pointer to POD as being a descriptor reference of an allocatable, well then you have a crash in the making.
So what is it? Is you example sketch wrong, your description wrong, or what you are trying to do wrong?
Jim Dempsey
mecej4
The FortranoPhone Devil's Advocate could combine #1 and #9 to create
INTEGER :: Istat
IF (ALLOCATED(Foo%BAR)) THEN
   DEALLOCATE(Foo%BAR, STAT=Istat, ERRMSG=ErrAlloc)  ! <= returns Istat of 0
      RETURN
   END IF
END IF
   RETURN
END IF
in which case, regardless of all the false scents made available by the OP (DLLs, BIND(C), possibly inconsistent interfaces, etc.), the behavior described in #1 would be completely logical. All of this goes to show that we really must have a correct description of the problem or, better yet, a reproducer.
jimdempseyatthecove
             //Foo%BAR\\
       //Foo\\
Foo%BAR is being tested and conditionally deallocated
Foo being allocated
Foo and Foo%BAR are different entities
You might have intended:
INTEGER :: Istat
IF (ALLOCATED(Foo) THEN
      RETURN
    END IF
    DEALLAOCATE(Foo)
END IF
   RETURN
END IF
Jim Dempsey
FortranFan
Jim, mecej4, Steve:
Thank you very much for your time and attention to this matter.  And sorry for any confusion thus far.  Shown below is some pseudo-code that better explains the situation.
  • DLL "B" encapsulates a derived type that also includes some allocatable components and certain type-bound procedures. Say this type is called FooClass and one of the allocatable components is Bar of type BarClass.
       MODULE FooClassMod
          USE ..
          USE BarClassMod, ONLY : BarClass
          USE ..
          TYPE, PUBLIC :: FooClass
             !.. Private by default
             PRIVATE
             !.. Private fields
             TYPE(BarClass), ALLOCATABLE :: m_Bar
          CONTAINS
             PRIVATE
             !.. Private methods
             PROCEDURE, PASS(This) :: CalcFooA
             PROCEDURE, PASS(This) :: CalcFooB
             PROCEDURE, PASS(This) :: InitFooA
             PROCEDURE, PASS(This) :: InitFooB
             FINAL :: CleanFoo
             !.. Public methods
             GENERIC, PUBLIC :: Init => InitFooA, InitFooB, ..
             GENERIC, PUBLIC :: Calc => CalcFooA, CalcFooB, ..
          END TYPE FooClass
       CONTAINS
          PURE ELEMENTAL SUBROUTINE InitFooA(This, .., ErrorCode)
             !.. Argument list
             CLASS(FooClass), INTENT(INOUT) :: This
             .. !.. Other scalar arguments
             INTEGER(..), INTENT(INOUT) :: ErrorCode
             !.. Local variables
             ErrorCode = 0
             IF (ALLOCATED(This%m_Bar)) THEN
                DEALLOCATE(This%m_Bar, STAT=ErrorCode, ERRMSG=ErrAlloc)
                IF (ErrorCode /= 0) THEN
                   .. ! do some error handling
                   RETURN
                END IF
             END IF
                RETURN
             END IF
             RETURN
          END SUBROUTINE InitFooA
          PURE ELEMENTAL SUBROUTINE CalcFooA(This, .., ErrorCode)
             !.. Argument list
             !.. Local variables
             ErrorCode = 0
             .. ! do some calculations involving private fields of FooClass
             RETURN
          END SUBROUTINE CalcFooA
       END MODULE FooClassMod
  • DLL "A" includes amongst other code a calculation module, say c, which has a procedure CalcSim that takes an argument of type FooClass and say it is named Foo:
       MODULE c
          USE ..
          USE FooClassMod, ONLY : FooClass
          USE ..
          PUBLIC :: CalcSim
       CONTAINS
          SUBROUTINE CalcSim(.., Foo, .., Err)
             !.. Argument list
             TYPE(FooClass), INTENT(INOUT) :: Foo
             !.. Local variables
             Err = 0
             IF ( ... ) THEN
                CALL Foo%Init(Err)
                IF (Err /= 0) THEN
                   RETURN
                END IF
             END IF
             CALL Foo%Calc(Err)
             IF (Err /= 0) THEN
                RETURN
             END IF
             RETURN
          END SUBROUTINE CalcSim
       END MODULE c
  • A main program, say p, allocates a type FooClass, say it is named FooInst, and amongst other things, it invokes CalcSim procedure with FooInst as one of the arguments:
       PROGRAM p
          USE ..
          USE c, ONLY : .., CalcSim, ..
          USE ..
          !.. Local variable type declarations
          TYPE(FooClass), ALLOCATABLE :: FooInst
          INTEGER(..) :: Err
          ALLOCATE(FooInst, STAT=Err, ERRMSG=ErrA)
          IF (Err /= 0)
             PRINT *, " Allocation of FooInst failed. ErrorCode = ", Err
             PRINT *, ErrA
             STOP
          END iF
          CALL CalcSim(.., FooInst, .., Err)
          IF (Err /= 0)
             PRINT *, " CalcSim failed. ErrorCode = ", Err
             STOP
          END iF
          STOP
       END PROGRAM p
  • The problem is the call to Init generic of Foo in CalcSim (refer to line# 35 in module c of above pseudo code) fails the second time it is invoked.  The failure mode is associated with the allocation of m_Bar component in InitFooA procedure (refer to lines 63 thru' 74 in module FooClassMod in above pseudo code).  IF (ALLOCATED(This%mBar)) check returns true, DEALLOCATE(This%m_Bar, ..) statement executes and error code comes back as zero, but the subsequent ALLOCATE(This%m_Bar,, ) returns an error value of 151 and a message of "an allocatable array is already allocated."
Note late yesterday, I thought my problems had something to do with a wrapper procedure to CalcSim that had BIND(C) attribute; since then, I've modified the actual code to follow the design pattern shown in the above pseudo code but the problem remains.
..   goes to show that we really must have a correct description of the problem or, better yet, a reproducer.
Look, all I am looking for immediately is some pointers on what all I can check - hope the description in this quote proves adequate.  I'm trying very hard to create a reproducer.  I'll post one as soon as I succeed.  Owing to several constraints, I can't provide details of other components in the FooClass nor any details of the BarClass.  But as I reduce the problem, my belief is that other details of FooClass and specific aspects of BarClass may not be that relevant if anyone is only trying to offer me guidance.
IanH
This seems familiar to me - I may have had the same sort of problem.  I have vague recollections it was due to a corrupted descriptor for a [polymorphic?  component of a polymorphic? component of a type that was printed out on paper and placed next to a dictionary with the word polymorphic in it?) (scalar?) allocatable component - exposed because the test for "are-you-allocated" and the test for "are-you-already-allocated-when-I'm-about-to-try-and-allocate-you" looked at different parts of the descriptor (one looks at the memory address, the other looks at flags?  Or maybe one was looking in completely the wrong place?  Or maybe I was looking in the wrong place?  Perhaps I'd been looking in the fridge?).  The complete absence of clarity (hence all the question marks) that I have about this problem indicates that it may have been a while back though.
If you feel brave or silly enough, have a look at the disassembly for the ALLOCATED intrinsic in your program, and try and work out what it is actually testing.  Then repeat the same sort of analysis for the error checking associated with the ALLOCATE statement.  That may give you insight for where the underlying problem might be.  Once the memory locations in the descriptor that are meaningful have been identified, things like hardware breakpoints can be used to try and understand where the wheels actually fall off.
</probably_not_adding_much_value>
Steven_L_Intel1
Are the DLLs and your EXE all linked to the DLL run-time libraries? They should be. If you provided a real, buildable and runnable example, analysis would go much easier. I've been burned too many times by pseudocode that didn't match the actual code.
FortranFan
Are the DLLs and your EXE all linked to the DLL run-time libraries? They should be. ...
Steve,
All the DLLs and the EXE are linked with the same Intel Fortran compiler version plus /libs:static /threads option i.e., Multithreaded option from the drop-down menu in Visual Studio for Fortran Run-time libraries.  I thought it is ok with everything is built with this option.  Comments?
... If you provided a real, buildable and runnable example, analysis would go much easier. I've been burned too many times by pseudocode that didn't match the actual code.
I understand and so I am working toward a small, simple reproducer; hopefully I'll succeed.  I notice that if I redesign the code structure a little, the problem shifts to another section where DEALLOCATE of another object fails with "access violation" error.  This suggests the issue I mention in the original post may be one of those oft-repeated phrases "unexpected processor behavior can be experienced" in connection with non-standard/nonconforming code.  So I do accept there is a problem somewhere in the code - the challenge is to diagnose it.
Steven_L_Intel1
No, absolutely it is NOT ok to link these against the static libraries. You can do this when there is a single Fortran DLL and the caller is not Fortran (C++ or VB), but when you have a Fortran EXE calling Fortran DLLs, you must link them all to the DLL libraries. Do that and my guess is that your problem will go away, as otherwise you have three copies of the Fortran libraries that don't know about the others.
FortranFan
Ok, that is a discussion for another day.
But I just did what you suggested i.e., linked all the projects involved (2 DLLs and a Fortran EXE) with "/libs:dll /threads" option i.e., Multithreaded DLL from the dropdown menu in Visual Studio: unfortunately, the program still fails in the exact same fashion :-(
Steven_L_Intel1
At this point I'll ask that you construct an actual example we can look at.
Steven_L_Intel1
FortranFan sent me a test case and I can reproduce the problem. It has been escalated to development as issue DPD200359690. The test case had DLLs and C code, but neither of those were necessary to see the problem.
