29487 Discussions
When are pure procedures not concurrency safe?
martin_upsdellagrese
I receive a message from the guided autoparallizer that I should insert "!dir$ attributes concurrency_safe : profitable" to enable the autoparallizer to parallelize the loop. I have declared the subroutine as Pure which I understood to declare it as being safe to use in a parallel loop as it decalres that the only items changed within the subroutine are dummy variables declared with intent(out) or intent(inout).
Are there otherthings I should be looking out for?
jimdempseyatthecove
Show us a code snip of your loop .and. the declarations of the variables used in the loop, plus the subroutine(s) that are giving you problems.
Many things can affect parallelization. When there is uncertainty, the compiler will remove vectorization. If your problematic subroutines are being passed scalars (and for functions returning scalar) it may be a candidate to flag as elemental as well as pure.
BTW
The Intel Developer's Forum (conference) is starting tomorrow. Many of the respondants to this forum message may be preparing to go and/or may not reply to your message(s) until next weekend. Be patient.
Jim Dempsey
TimP
This compiler message appears to be concerned more with performance than safety of threading. If the suggested directive does result in parallelization, you should test to see whether it produces desired performance.
You should be looking out for the usual questions; would there be good thread locality of data, are the loops sufficiently long, can parallelization be performed without removing vectorization, ...... ?
Giving a procedure the PURE attribute specifies that it does not have side-effects, but this does not make it concurrency-safe. For example, a PURE procedure may still use static storage for local variables, though if you have enabled /Qparallel, it will use the stack instead. More to the point, PURE does not safeguard against unsynchronized reads of memory elsewhere in the program, which CONCURRENCY_SAFE specifies.
