Which Parallel Studio 2019 supports VS 2019?
bbaltz505
Hello.
We have been using the Fortran compiler from Parallel Studio XE 2019 Composer Edition with Visual Studio 2017 Pro for some time. I tried a reinstall of Parallel Studio to use with Visual Studio 2019 but it does not seem to support it. This particular installer only lists 2015 and 2017 for Visual Studio Integration. Is there a more recent version of Parallel Studio that supports VS 2019? Windows shows I have Parallel Studio XE 2019 2019.0.0.45 installed.
Also, when I attempt to download a more recent Parallel Studio XE 2019 installer, I'm only given a 'Cluster Edition' installer - which does not agree with our floating license.
Brian
Barbara_P_Intel
VS2019 was first supported with the 19.0.4 compiler.
This article has a table of Intel compiler versions and which versions of Xcode and VS are supported.
For your licensing question, please submit a support ticket here. Click Priority Support.
bbaltz505
Thank you for the link. I'm assuming that's in the 2019 Update 4 installer? I managed to find a Composer Edition installer on https://registrationcenter.intel.com/en/products/.
I ended up installing 2019 Update 5 and it works fine with VS 2019.
Brian
Barbara_P_Intel
Great!
